Resetting All Time Records
Karlsm
Post by Karlsm »
Hi all,
I'm new to this forum but not new to Meteobridge having used the standard for some years now. I've recently updated to Nano SD and since initial setup, I have noticed all of my All Time Records are completely inaccurate, I don't know where these cam from. I've no data to import but I'm relocating so I be starting climate readings for a new location shortly but how can I clear my all time records and start from scratch and to resolve this before new year commences....
Also, can the NANO import records from my VP2 console? Temp/Baro Max/Min, rainfall, rain rate etc etc
I have looked through the forum and I can't reproduce any solutions to my setup.
Re: Resetting All Time Records
NANO SD computes min/max data from the logged data only, it does not read historical data from the console.
But as you can edit the database, you can insert values manually to make your min/max and totals to fit your needs.
Karlsm
Post by Karlsm »
Is there any way to correct bad data that I edited and was sent to Weather Underground from MB so I can keep data accurate. It’s a continuing issue with max/min. I wanted to keep my rainfall for the year accurate and then reset it an end of year as it’s a significant year for rainfall here. I since edited this particular day on MB but has not reflected in WU? I need to get rid of this total for this day but can’t figure out how. This bad data has shown up on
you can edit all values on the Meteobridge side. Not sure how to correct data on the WU side.
