Directory Error when connecting to Davis Datalogger. **solved**
jw5613
Post by jw5613 »
My Meteobridge TL-MR3020 cannot connect to my Davis Vantage Pro2 datalogger on my Davis console.
Looking at the log this is what is occurring:
logger (05.12.2023 10:35:26): data logger (version 5.4, build 15131) started.
logger (05.12.2023 10:35:27): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (05.12.2023 10:35:27): station 0 (Vantage), connect to station failed.
logger (05.12.2023 10:35:30): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (05.12.2023 10:35:30): services paused.
I have tried powering down AC power and batteries from the console. Disconnected the datalogger. Waited a minute and started up the console again. Before hooking it via usb to the meteobridge, I powered down the meteobridge, connected the usb hub to the meteobridge and powered back on. Unfortunately it did not work. This all started when I set up a new router and powered down the meteobridge, then restarting it after the new network was online. It always worked flawlessly for the last few years. Any help is welcome.
Re: Directory Error when connecting to Davis Datalogger
Do you use the mandatory USB 2.0 hub?
jw5613
Post by jw5613 »
Yes, I use the mandatory USB hub.
However, the USB logger is not recognized by Meteobridge. Please check connections etc.
jw5613
Post by jw5613 »
I checked all connections again and everything is fine as far the cabling goes and I also disconnected and reconnected everything from the data logger to the USB and then to the Meteobridge. I did notice on the information tab it says TL-MR3020 (no USB hub). Could it be that the USB hub is bad?
jw5613
Post by jw5613 »
Problem solved after replacing the USB hub. Data is flowing to the web again. The old one must have gone bad somehow. Thanks for the help and suggestions.
