Unable to image new SD Card (RPI 3B+). **solved**
monymony
Post by monymony »
I am trying to setup a new RPI unit (a 3B+) but whenever I try to image the SD card (a recommended SDSDQED-008G-XI) the RPI will not load. I have tried a separate SD card with same results. I have also imaged the card with other Raspberry PI images and those all will successfully load, so only when I try to image with the 'meteobridge-rpi3-v1.3.bin' file that the process fails. I typically work on MacOS and have tried both the Etcher and Raspberry Pi Imager and both have the same unsuccessful results. I even tried to use a Win11 machine to create the image and it too fails to load. I have also tried the suggestion in other posts to do a FAT32 format first but no change.
I am aware from older posts that there was past compatibility issues with the 3B+, but the current requirements (https://www.meteobridge.com/wiki/index. ... g_Hardware) clearly show this is a supported configuration. I am at a loss as to what to try next. Does anyone have any suggestions on what options I can try.
Re: Unable to image new SD Card (RPI 3B+)
I use the RPI Imager to bring "meteobridge-rpi3-v1.3.bin" to the microSD card. Booting from there on my Raspberry Pi 3 Model B Plus Rev 1.3 works fine.
Did you watch the boot process via serial port? Or how do you come to the conclusion that "it does not load"?
monymony
Post by monymony »
I don't have a cable to monitor via serial (not yet... just ordered one). I get nothing when trying to monitor the HDMI connection, through I am not convinced the boot is getting far enough to even activate the HDMI port. I just immediately get that blinking green light sequence, 4-long, 7 short, that repeats forever. If I reimagine the SD card using the RPI imager to another OS option, things boot normally. I can see when I view the contents of the card on with MacOS that the image did get created when I use the Meteobridge file but the RPI does not like it.
Unless someone has a eureka-moment, I will circle back next week after I can monitor the boot via serial.
Meteobridge does not take care of any HDMI ports etc. It is a headless device. You need to know the IP (wiki explains how to find out) and browse to this IP.
monymony
Post by monymony »
To update this post, I did get the serial cable to monitor the boot and with the Meteobridge image I get nothing. Any other image I try works fine, just not the image I downloaded for my 3B+. So at this point I have given up and converted this 3B+ into my new Homebridge device which is working just fine. I will soon try again, but this time with a RPI 4.
[Further Update] I purchased a RPI 4B and had no issues imaging the device. Not sure why the 3B+ was so problematic for me.
