Pressure via Meteobridge 20 hPa higher than direct ecowitt Upload. **solved**
twassmer
Post by twassmer »
My air pressure uploads through Meteobridge are more than 20 hPa higher than direct uploads from EasyweatherPro. It seems to use a different pressure sensor as standard that is not calibrated. How can I fix this?
Thanks in advance.
Sincerely, Tom
Re: Pressure via Meteobridge 20 hPa higher than direct ecowitt Upload
Meteobridge is uploading to where by what process/means? Is the pressure value coming from MB or a connected PWS?
First would check the MB config Station/Settings page, Station Alt etc There is also different pressure values in the MB, station pressure (thb0press) and sea pressure (thb0seapress) both default to hPa but can be converted.
Calibration is also another option but typically not required in most cases. In any case this would not be a calibration issue.
twassmer
Post by twassmer »
Hi. Was a calibration issue. This is good now.
