Meteobridge/Raspberry 5B
Großvater
Post by Großvater »
I have a Raspberry 5B,
Does this also work with the Meteobridge software?
or has anyone already gotten it to work?
Or is this only possible if it is officially approved by the company.
if so, will the RPI 5b ever be added to the compatible devices
Thanks for the help
Re: Meteobridge/Raspberry 5B
Currently not supported. I will purchase one and will check if it is worth the porting effort. Specs look far above what a Meteobridge needs and excessive power demand and heat generation is what many Meteobridge users try to avoid. But I will have a look.
Großvater
Post by Großvater »
I know the device is overqualified,
Thank you very much for your effort
Großvater
Post by Großvater »
admin wrote: Mon Feb 26, 2024 2:09 pm Currently not supported. I will purchase one and will check if it is worth the porting effort. Specs look far above what a Meteobridge needs and excessive power demand and heat generation is what many Meteobridge users try to avoid. But I will have a look.
Hello
I would like to ask what the current status is,
It will be possible to use the RPI-5b
Thank you very much
