which MB script produces the data for MeteoTemplate?
Bagtjesen
Post by Bagtjesen »
I do not find a anything like a script that produces the file for MeteoTemplate in MB?!
I need to understand how the file that is sent to MeteoTemplate (MT), every 5 minutes, from MB which has per minute logging - How does it select data and calculates it - this is to be able to fill in missing data into MT in a very similar way.
I am aware of the way that some things like wind speed and gusts differ by definition.
This is part of my redundancy project involving data taking two different paths from my VP2 Pro+ into separate computers as well as having a completely separate low cost ws.
MB produced file getting into MT with f ex with a timestamp displayed of 09:00- does that contain data from 8:56, 8:57, 8:58, 8:59 and 9:00? I have tried various start and ending minutes. I have taken into consideration that MB (PRO RED 5.7 (oc 18 2923, build 15079) FW 1.4) is set to TZ Europe/Stockholm.
Regards,
Bagtjesen
Gyvate
Re: which MB script produces the data for MeteoTemplate?
Post by Gyvate »
why do you want to put the cart in front of the horse ?
It seems that you do not understand how MT works - and now want to do something from the MB end introducing (unnecessary) restrictions.
What do you want to do in the first place ? Backfill missed data ?
When you tell what all you want to do, we can find a solution.
But from what I read in between your lines, your request sounds pretty weird to me - or maybe just badly expressed.
Tell what you are missing at the MT end and we can see how and if to do something from the MB end ...
MB posts data in the interval you define - e.g. you say every 5 seconds, it's every five seconds, you say one hour, it will be once every hour.
You better make a list of all data items you want to post to MT, define your resolution, define your accumulation rules and we can take it from there.
In fact, if you read the MT documentation, you will see what the posting string is supposed to look like and you can see what modifications you can make if you think you need to.
you will also have to understand what happens where - MB, MT. What you can change and what not.
but without a proper "project" description (not such a vague story as in your post), you won't get far.
