Yearly rainfall graph error * solved **
oliverb
Post by oliverb »
The WDL yearly graph is not showing the correct data.
If you loook at the next image (see reply)from Meteohub itself you can see I started meteohub Nov 2007 so there should be no data before that.
Also there is data missing on WDL for months Jan Feb March.
Brett. Image
oliverb
Re:Yearly rainfall graph error
Post by oliverb »
Correct last year graph from Meteohub for above post. Image
oliverb
Post by oliverb »
Weather-Display ClientRaw Parser shows
187 Rain Month Total 01 M - mm = 0 in
188 Rain Month Total 02 M - mm = 0 in
189 Rain Month Total 03 M - mm = 0 in
190 Rain Month Total 04 M 19.69 mm = 0.78 in
191 Rain Month Total 05 M 65.58 mm = 2.58 in
192 Rain Month Total 06 M 112.56 mm = 4.43 in
193 Rain Month Total 07 M 25.78 mm = 1.01 in
194 Rain Month Total 08 M 110.69 mm = 4.36 in
195 Rain Month Total 09 M 68.63 mm = 2.7 in
196 Rain Month Total 10 M 66.52 mm = 2.62 in
197 Rain Month Total 11 M 30.86 mm = 1.21 in
198 Rain Month Total 12 M 72.22 mm = 2.84 in
Nov 2007 should be 19mm
Dec 2007 should be 65mm
etc etc
Jul 2008 should be 72mm
Looks like the months totals are recorded OK but are stored against the wrong month.
Hope this helps.
Brett.
Yes this is a bug. Will be fixed with 2.7a.
oliverb
Post by oliverb »
Have loaded 2.7a. Yearly rainfall graph now works fine.
