Hi, I have the new ECOWITT hp2560 _ c 7 console. By inserting a new WS90 station with many sensors from the ECOWITT ecosystem into the meteobridge I have an error on the data. The error that occurs in the meteobridge with 2 WH/WN51 sensors (soil moisture) + 1 WN34 sensor (soil/pool temperature) happens that the temperature is entered in the Soil field causing one of the two sensors to disappear. If I turn off the WN34 the second soil moisture also reappears. Furthermore, the WN35 leaf sensor is read, but instead of the Leaf description it presents Outdoorxx, it is not clear that it is a leaf sensor.
How can I solve the problem? Thank you.
P.S. - On the console (firmware 5.1.6) to upload the data to the meteobridge I choose a station with the "ECOWITT CUSTOM UPLOAD" module with the script path /public/ecowitt2.cgi. Is this the file to use?
