I've been trying unsuccessfully to install Meteobridge on an RPI 3 B+. I have the correct MicroSD. I used Raspberry PI imager to move the files to the SD. Lights on the RPI: Red stays lit solid. Green blinks a fast pattern of two different sequences. This RPI loads and runs fine with PI image. What am I doing wrong? From what I've read, that version RPI is now supported?
TIA
Paul
Meteobridge on RPI 3 B+ compatible?
Re: Meteobridge on RPI 3 B+ compatible?
Never got the RPI 3 B+ to work. Bought an RPI 4 B and it fired right up. Not sure whats up with the RPI 3B+ as it runs fine with a PI image on it.
I'm having the same problem, is anyone using the RPI 3B+? Can you help me, I can't get it to work
Hi Boris, will it be possible to check if everything is fine in the image in the latest update for RPI B3+?
We have already tested with two RPI, the hardware works perfectly. We have followed all the steps but it does not boot
I finally bought a Raspberry Pi Model 4B and it definitely works correctly with MB v1.4.bin, now I have to test if it works with WiFi. Good year!
Hi I have already downloaded the new update v 1.5 in my RPi 4B, it works correctly now with WiFi! Thank you very much for solving it Boris!
The RPI 3B+ also works perfectly. I forgot to mention it. Thanks
I have three working meteobridge servers, I wanted to add a fourth server, but I seem to have the same problem as Plemieux. I tried 3 different Raspberry PI 3B+, I tried several compatible SD cards (8 and 16GB), I tried several programs to unpack the meteobridge-rpi3-v1.3 file, but none of the actions were successful in my case. After connecting the power supply, the Raspberry flashes an error with the green LED - 4 long and 7 short flashes. Is there any solution to be able to run Meteobridge on the Raspberry PI 3B+? Thanks
