Camera +Text has wrong info. **solved**
captgadget
Post by captgadget »
When in Meteobridge Weather Nets I go to Meteobridge Weather Camera and it shows me the correct image for time and date. Then when I go to the camera+Text the information is no longer correct. The IP address did get changed but I now have the correct IP address so I don't understand what I need to change to get the correct Camera+Text information.
captgadget
Re: Camera +Text has wrong info
I don't know if this helps or not but I deleted everything in the line in Overlay Text, then clicked the Camera+text and it shows the same picture from 12 days ago. But if click just camera one, it shows the current picture. So how do I get the current picture with the overlay text to show up?
When picture is too large it may not upload and old one stays on the server.
Any information on "Monitoring - Upload Status" tab about cam uploads?
What is your MAC? Having that I can check if your Meteobridge connects with the server for cam uploads.
captgadget
MAC: D8:3A:DD:2E:57:86
I can confirm that for your mac a CAM file is written onto my server.
Both are looking the same and are recent. camplus file is much smaller. If you intended some data overlay, this is currently not applied. May be you are using the wrong link or you browser cache is fooling you?
I send you the link via PM.
captgadget
Thank you Do you know someone who can help me get the right coding for the overlay information?
captgadget
Thanks so much. Appreciate your help. I cleared the cache in both Safari and Chrome and it now shows the right information.
I got it working on awekas also! Thanks again
