Windy API Invalid **solved**
grwkak
Post by grwkak »
Anyone else using Windy to display data and running into "invalid API key error".
This just appeared and I tried changing the API key - actually, this confounded me a bit as I don't remember where I got this from so I created a new plugin key.
Guy
grwkak
Re: Windy API Invalid
Post by grwkak »
Actually I found the correct area and my key - seems the error started maybe around 5- 6am EST today. Maybe its a Windy server issue?
Guy
grwkak
Post by grwkak »
*Edited* In looking further - there does not seem to be a pause or gap in data - just the error message on the Meteobridge. Upload status shows "success" but Weathernets tab says "Error: Windy: invalid API key or connection error". Updated to latest build just in case - no difference.
Guy
grwkak
Post by grwkak »
@admin any idea what is happening here. Seems to be more of an annoyance than an issue as data are getting to Windy.
Guy
To my current understanding windy rejects data when more often sent as every 5 mins. This also applies to the credentials check on "Weather Network" tab.
I will remove credentials check on "Weather Network" tab for Windy. Hopefully, Windy will no that often freak-out anymore.
grwkak
Post by grwkak »
Mine is set for a 10 min interval - always possible its changed protocols.
Guy
Discussed SW update has been released.
grwkak
Post by grwkak »
Rebooted and loaded new version - seems to work so far! Thanks.
Guy
