Meteobridge PRO / Impossible to edit hour or minute data
Posted: Mon Jun 17, 2024 4:15 pm
by oncletom17
I need to edit my rain data due to a bug (25.6 mm saved but 0.0 mm in the reality).
But editing the hour data is impossible. When I click on the valur, nothing happens...
How can I edit this?
Re: Meteobridge PRO / Impossible to edit hour or minute data
Posted: Mon Jun 17, 2024 4:25 pm
by davidmc36
Is there an issue with blocked pop-ups maybe on your browser?
To edit value, a remote window pops up when I click on the value.
Posted: Mon Jun 17, 2024 4:27 pm
by davidmc36
Like this:
- MBEdit.jpg (173.77 KiB) Viewed 3594 times
Posted: Mon Jun 17, 2024 4:34 pm
by oncletom17
Hi davidmc36,
I checked the pop-up parameters and tried on my phone and with 2 different browsers.
But I see you have a local/IP connection.
I was trying tio edit the data by remote access (I'm actually not at home).
Is this the reason why?
Posted: Mon Jun 17, 2024 5:35 pm
by oncletom17
Now I'm at home... editing with IP access doesn't work
Posted: Mon Jun 17, 2024 6:44 pm
javascript needs to be enabled in your browser.
Posted: Mon Jun 17, 2024 6:48 pm
by oncletom17
admin wrote: Mon Jun 17, 2024 6:44 pm
javascript is enabled
Posted: Mon Jun 17, 2024 6:49 pm
Are you using most current Meteobridge version?
Posted: Mon Jun 17, 2024 9:50 pm
by oncletom17
I'm on the version 5.7
EDIT: I've just updated to version 6.0, but the problem persists.
Posted: Mon Jun 17, 2024 11:06 pm
As it works for all other users it must be something with your browser.
When you give me remote access, I can try myself. "info(at)meteobridge.com"
Posted: Tue Jun 18, 2024 8:30 am
Thanks for providing me a login. Issue was that the French translation contained an unquoted ' which confuses the JavaScript where it is embedded into. I fixed that in just released update.
BTW: Translation makes the first menu line too long, which looks odd. Could you provide shorter tab names so that I can adapt?
- frenchtab.png (60.34 KiB) Viewed 3531 times
Posted: Tue Jun 18, 2024 9:48 am
by oncletom17
thanks for solving the problem!
to shorten menu names, you could write: "Editer données d'heure" "Editer données de minutes" but you'd only lose a few characters
Posted: Tue Jun 18, 2024 12:26 pm
oncletom17 wrote: Tue Jun 18, 2024 9:48 am
First line is giving me headaches, because it runs away from the frame at the left. Any suggestions there?
Posted: Sun Aug 18, 2024 4:24 pm
by oncletom17
admin wrote: Tue Jun 18, 2024 12:26 pm
Sorry, I didn't answer to you. Which line do you talk about?
