Ecowitt Sensor WH46. **solved**
Stebi
Post by Stebi »
Hi
I use Meteobridge on a Raspi Pi 3, Model B+, Firmware 17.06.2024, build 3172. My 2nd weather station is a Ecowitt (Model GW1000) and I just added the new sensor WH46 (CO2, etc.). The Ecowitt app is sending data and I can read the results in the Ecowitt App and on the internet https://www.ecowitt.net/home/share?authorize=KR7F5P but Meteobridge is not receiving these data. What do I have to do, to correctly integrate this sensor into Meteobridge?
Grüsse aus Basel
Thomas
Stebi
Re: Ecowitt Sensor WH46
Post by Stebi »
Addendum:
I deinstalled the corresponding weatherstation in meteobridge and reinstalled it afer a few minutes.
The data from sensor WH46 were not recording. It seems that Ecowitt sensor WH46 is not compatible with meteobridge.
Thomas
Have you already updated the firmware?
The sensor should be supported since the release of 01.06.2024.
https://www.meteobridge.com/wiki/index.php/Forum
Stebi
Post by Stebi »
Yes, I allready updated to version 27.06.2024.
I installed a 4th weatherstation name "Ecowitt custom Upload". Now I get the data into meteobridge. Although now in double and two Air-data are still missing.
Thomas
