any raspberry pi Guru on this forum? **solved**
pinto
Post by pinto »
The reason I ask is the folowing:
I write a new sdcard today with the .bin file downloaded to my ubuntu 22LTS computer and use Raspberrypi imager to do so.
after starting up everything works fine exept for the dashbord.
I write a new sdcard on the same computer with dd.
after starting it up everything works perfect exept for the dashbord.
I write a new sdcard with a windows computer and Raspberrypi imager.
after starting it up everythin works perfect exept for the dashboard.
using ssh on linux or putty on windows I did find some x86 packets in /tmp/mnt/PWS
So they are normaly there for installing php on the raspberry so you can use the Dashbord.
But X86 code will not woek on a raspberry.
Now, my question is: is someone of you specialists willing to do the same experiment with a SPARE card and a SPARE raspberry?
it is the same for raspberry 3 or 4.
DO NOT USE A PRODUCTION SYSTEM FOR THAT EXPERIMENT
YOU CAN BRAKE YOUR SYSTEM
Re: any raspberry pi Guru on this forum? **solved**
How did you solve your issue? Might be interesting for other users.
pinto
Post by pinto »
Released June 26, 2024
Meteobridge RPI: fixes a bug that prevents from re-installing the Dashboard.
