Red Meteobridge Pro
ke5wth
Red Meteobridge Pro
Post by ke5wth »
Starting about a month ago, my bridge will show it is not recieving any signals, then in the morning, it starts logging again. My Davis consoles show no issues. I have added a taller 915mhz antenna and i see better signals, but it still seems to stop working usually at night. Has anyone else seen this problem. My Device was bought February 2022.
Re: Red Meteobridge Pro
Obviously the not working at night time and starting again in the morning for Davis systems typically indicates power issues but as the consoles remain up then may not be simple to diagnose?
So for how long before "starting about a month ago" was it working ok? What might have changed around a month ago?
Once a larger antenna is required then that tends to indicate being on the verge of signal issues? What is the distance between Bridge and ISS? What is the Bridge Sensitivity setting (Station>Primary Station) and what does the live data (Monitor>Live data) tab show during these Bridge outages?
