Meteobridge VM - SFTP test upload failed : sshpass. **solved**
Wheetie
Post by Wheetie »
I'm trying to set up my new Meteobridge VM, and have run into another snag. It doesn't appear that SFTP upload is working. I searched the forums and saw that there was a SFTP error issue with the Pro2, but I didn't see anything regarding the new Meteobridge VM install.
The same username and credentials work on my RPi3 and RPi4 Meteobridge appliances, and upload to my local web server running the Saratoga templates. So I don't think it's a server-side issue. I'm also able to ssh into the Meteobridge VM, and then ssh into the local web server from the Meteobridge VM using these same credentials.
I notice on my RPi3 and RPi4 instances that I get a green check mark next to the host IP, but there is a red X in the VM.
Does any one else have SFTP upload working in a Meteobridge VM?
Thanks for the help,
Wheetie
Screenshot 2024-07-19 at 8.59.52 PM.png (67.47 KiB) Viewed 1404 times
Re: Meteobridge VM - SFTP test upload failed : sshpass
Thanks for spotting this. I will check.
I removed the bug in the just released update.
Wheetie
Post by Wheetie »
admin wrote: Tue Jul 23, 2024 4:12 am Thanks for spotting this. I will check.
Excellent, thank you for the quick response and resolution. I just tested this and both the SFPT test and the Upload Events are working. Thanks again!
Wheetie
