Update issue
ON8AZ
Update issue
Post by ON8AZ »
I have been using a meteobridge red for a few years now and to my great satisfaction. But since the updates at the end of July I have had problems and it no longer works.
I have tried everything but without success. The supplier thinks the mainboard is broken, which is strange after an update.
Has anyone else had this? See the attached screenshots. I can no longer select my weather station, there is a prohibition sign.
Thx in advance.
see screenshots:
https://app.screencast.com/7Y59o0nwGWlvw
https://app.screencast.com/4qtvKpLCN6d57
Re: Update issue
when you give me remote login, I can check if HW is ok.
ON8AZ
Re: Update issue
Post by ON8AZ »
In the meantime I have contacted Boris from meteobrige who also suspects that it is a hardware problem. (USB HUB Failure).
I was allowed to send the MB for repair. Which I have done in the meantime. Thanks for the help anyway.
Re: Update issue
User admin and Boris are the same person :wink:
