Events gone after upgrade to latest version. **solved**
robr57
Post by robr57 »
HI,
My Meteobridge was running smooth for > 6 months. Today I had to reboot due to power outage.
When starting I got message in RED:
WARNING: 12 event definitions have been converted into a new format..... etc.
In the Events page, I now only see 5 events. All my other events are gone ????? This includes several FTP uploads etc. to my Home Automation.
According to Forum there should be multiple tabs with Event definitions ? I only see one. Where can I find my old definitions ?
Re: Events gone after upgrade to latest version
Can you please give me remote access to your Meteobridge? Please send credentials to "info/at)meteobridge.com".
Do you have a copy of your settings file from before the migration?
robr57
Post by robr57 »
Boris,
Unfortunatly my backup for settings was too old... I did analyse it and was able to restore 2 events from it (FTP).
Meanwhile I have reconstructed all events and rebooted several times.
If I recall correctly, I did have one or 2 events that were turned off. It looked like these events and the following were gone.
Would it still make sense to have access to analyse the cause ? Then I can provide the access.
I found one other issue, and that was that also my Davis Airlink was no longer there.
Looking at my old backup, it looked as if that was partly restored, as this was the initial setup I made in 2020 .
Thanks for your attention anyway.
That is right, deselected events might not be transferred. Sorry, I did not test this edge case.
Good to know that you are back on track.
Re: Events gone after upgrade to latest version. **solved**
I did not note any issues with the May release and multiple event tabs. All events active/on or disabled/off came across with multiple tabs.
