Cumulus Import incorrect units for wind speed
lightmaster
Post by lightmaster »
I'm trying to import some Cumulus MX data into MB NanoSD. I converted all of the imperial units from the Cumulus MX data to their respective metric units, but I noticed that the wind values were significantly lower than the numbers in the .sql file I imported. For instance, a value of 2.64m/s in the imported file, shows up on the database file as 1.2m/s. Out of curiosity, I converted 2.64mph to m/s, which is 1.18m/s (rounds to 1.2). I then took a small sample of the .sql file and inserted all of the wind values as their mph values instead of m/s values, and now that time frame in MB's database is showing the correct m/s values.
It looks to me like there is a conversion error in the Cumulus import logic, where it is converting the wind values from mph to m/s, meaning that while the Cumulus import wants metric for all of the other values (temp, pressure, etc), it's wanting imperial for the speed values.
Re: Cumulus Import incorrect units for wind speed
Thanks for sharing your observations.
