Station selection with Froggit DP2000. **solved**
Xanti19
Post by Xanti19 »
I successfully installed Meteobridge VM in Proxmox. The aim is to test the Froggit DP2000, probably Ecowitt Wittboy, via the IP from the gateway. When I select the station, I only see GW1000, but not GW2001 Wittboy. With the selection GW1000 and the corresponding gateway IP, weather data from the DP2000 arrives in Meteoridge. Is the GW2001 selection only available in other Meteobridge versions? Would this selection be able to do more?
Re: Station selection with Froggit DP2000
There is no important “difference” between the glass-less Ecowitt consoles. At least not for a weather program.
So there is no need to differentiate between a GW1000 GW1100 GW2000 and so on.
Most or all of the sensors can be read by any of them.
It all depends on the firmware release which is frequently updated by Ecowitt.
regards,
