MB VM not enough space to repair database
Gyvate
Post by Gyvate »
setup (25.08.2024 12:09:28): use UTC stamp 2024-08-25 10:09:28 (1 tries)
dbrepair (25.08.2024 12:09:32): database size is 9.8G.
dbrepair (25.08.2024 12:09:32): test integrity of database.
dbrepair (25.08.2024 12:09:32): RAM database integrity is fine, nothing to do.
dbrepair (25.08.2024 12:09:33): not enough free space to repair database.
dbase (25.08.2024 12:09:34): process started.
/tmp/mnt/data/backup$ df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 125.5G 23.2G 95.8G 20% /
tmpfs 116.5M 53.8M 62.7M 46% /tmp
tmpfs 512.0K 4.0K 508.0K 1% /dev
how is this possible ?
MB won't start the rebuild/repair process - option was: forced rebuild on reboot
A complete shutdown and restart of the VM didn't make any change ...
Re: MB VM not enough space to repair database
That should be fixable. Can you please provide me remote access?
Gyvate
Post by Gyvate »
I have meanwhile removed a 10 GB backup file from the RPi which it didn't seem to like.
Then after a full restart of the VM, not only a reboot, it's behaving properly again.
So for that probably a remote login won't give any insights
What is strange is now that during backup it brings error/warning messages of the type
backup (30.08.2024 10:12:00): backup completed: dbase-202408301000.gz (1.2G)
backup (30.08.2024 12:00:00): backup media size is 125.5G (63.4G free).
backup (30.08.2024 12:00:15): WAL file cannot be resolved, backup might be incomplete.
logger (30.08.2024 12:03:30): transfer of sensor data to database timed out: th2!9temp
logger (30.08.2024 12:03:35): transfer of sensor data to database timed out: th2!9hum
logger (30.08.2024 12:03:40): transfer of sensor data to database timed out: th2!9dew
logger (30.08.2024 12:03:45): transfer of sensor data to database timed out: th2!9heatindex
logger (30.08.2024 12:03:50): transfer of sensor data to database timed out: th2!9wetbulb
logger (30.08.2024 12:03:55): transfer of sensor data to database timed out: th3!1temp
logger (30.08.2024 12:04:00): transfer of sensor data to database timed out: th3!1hum
logger (30.08.2024 12:04:05): transfer of sensor data to database timed out: th3!1dew
logger (30.08.2024 12:04:10): transfer of sensor data to database timed out: th3!1heatindex
logger (30.08.2024 12:04:15): transfer of sensor data to database timed out: th3!1wetbulb
logger (30.08.2024 12:04:20): transfer of sensor data to database timed out: th3!3temp
logger (30.08.2024 12:04:25): transfer of sensor data to database timed out: th3!3hum
logger (30.08.2024 12:04:30): transfer of sensor data to database timed out: th3!3dew
logger (30.08.2024 12:04:36): transfer of sensor data to database timed out: th3!3heatindex
logger (30.08.2024 12:04:41): transfer of sensor data to database timed out: th3!3wetbulb
logger (30.08.2024 12:04:46): transfer of sensor data to database timed out: th3!7temp
logger (30.08.2024 12:04:51): transfer of sensor data to database timed out: th3!7hum
logger (30.08.2024 12:04:56): transfer of sensor data to database timed out: th3!7dew
logger (30.08.2024 12:05:01): transfer of sensor data to database timed out: th3!7heatindex
logger (30.08.2024 12:05:06): transfer of sensor data to database timed out: th3!7wetbulb
logger (30.08.2024 12:05:11): transfer of sensor data to database timed out: th3!25hum
logger (30.08.2024 12:05:29): transfer of sensor data to database timed out: th3!7wetbulb
logger (30.08.2024 12:05:39): transfer of sensor data to database timed out: thb0press
logger (30.08.2024 12:05:46): transfer of sensor data to database timed out: thb1!0temp
backup (30.08.2024 12:15:27): backup completed: dbase-202408301200.gz (1.2G)
if you still want to login - let me know
My offer was focussed at the "not enough space" error which does not seem to be correct as you have plenty of free space.
Gyvate wrote: Fri Aug 30, 2024 12:49 pm logger (30.08.2024 12:03:30): transfer of sensor data to database timed out: th2!9temp
These errors just tell that logger cannot reach database for storing new data while backup is running.
Gyvate
Post by Gyvate »
admin wrote: Fri Aug 30, 2024 1:14 pm My offer was focussed at the "not enough space" error which does not seem to be correct as you have plenty of free space.
I know - and the error is no longer showing :D
Gyvate
Post by Gyvate »
admin wrote: Fri Aug 30, 2024 1:16 pm
Gyvate wrote: Fri Aug 30, 2024 12:49 pm ....
I would expect the data to be transferred to the WAL (write ahead log) file during backup and retroactively posted by the database once the backup is completed ...
Gyvate wrote: Fri Aug 30, 2024 2:31 pm
Tell the sqlite developers :D
