Guidance/recommendations
elav
Post by elav »
Hello!
I had a MeteoHub setup running on an iConnect. It was feeding information to a website running WeatherDisplay Live. Unfortunately this died years ago - so I'm looking to set this back up. A lot has changed during this time and looking for guidance from this forum. Should I simply setup MeteoHub on a Raspberry Pi 4 or setup a Meteobridge on a TP-Link? Can this feed info to a website running WeatherDisplay Live?
Re: Guidance/recommendations
Meteobridge on TP-Link will feed weather networks but will not have persistent weather data on itself.
Meteobridge NANO SD, PRO2, VM or a self-build RPI solution will store weather data locally.
Weather display is just partially supported by Meteobridge (especially with TP LInk). However, I would the dump 20 years old weather display and replace by weather34, which is so much better.
So it depends, what you are looking for.
