WD Live - no graph information - SOLVED?
I just got my Meteohub setup with WD Live - but I am not getting any of the graphs displaying when you click on graphs or individual instruments... Do I need to wait for a 24 hr cycle as I can't even get the last hour of wind to work or show any data... Any thoughts? I have all 4 files being sent and I have confirmed that they are there on the server and being updated...
http://westwoodsweather.com/weather/liveweather.html
Gregg
Gregg
Re:WD Live - no graph information?
Same happens to me!
Can anybody who is currently using WD explain what are the steps to have it working?
TIA,
Chill
TIA,
Chill
Hi Gregg,AAMFlyer wrote:I just got my Meteohub setup with WD Live - but I am not getting any of the graphs displaying when you click on graphs or individual instruments... Do I need to wait for a 24 hr cycle as I can't even get the last hour of wind to work or show any data... Any thoughts? I have all 4 files being sent and I have confirmed that they are there on the server and being updated...
Gregg
your clientrawextra.txt and clientrawdaily.txt and clientrawhour.txt files are all empty
http://westwoodsweather.com/weather/clientrawextra.txt
http://westwoodsweather.com/weather/clientrawdaily.txt
http://westwoodsweather.com/weather/clientrawhour.txt
Have you enbabled uploading them from Graph upload menu in meteohub?
There also seems to be a problem with your clientraw.txt file as your applet shows NaN errors for Wind, rainAAMFlyer wrote: I have all 4 files being sent and I have confirmed that they are there on the server and being updated...
Are you on 2.7 version of meteohub?
If not, I would recommened updating it, because the 2.6 version had some error resulting in such NaN´s.
Then go to WD Live menu select your sensors and press SAVE to create a new WD Live template. That is a must, otherwise the old templates with the known bug are further in use!
Wolfgang
Sorry for German with the screenshots, but I didn´t want to chnage my menu language. Hope, it works anyway.
Thanks for your help Wolfgang!
I am using the most current version 2.7 and I have enabled uploads in the graph uploads section. They are actually uploading according to the schedule - but they are empty files as you can see! I've also assigned my sensors in the WD Live menu and saved that too. The base file is providing current conditions fine but the others are empty.
I'm at work now and perhaps I need to just go back and re-save the WD Live menu and see if that does anything to fix the problem...but right now I can't figure out why the .txt files except for the base file are basically blank with no data!
Everything is a new install this weekend - my original version was 2.3 - then I installed 2.6 - then I installed 2.7.... I created the template after I installed v2.7. Everything else is working well including uploads to WUnderground! Thanks!
In my case I have 2.7 (last version), all 4 files in \\myweb\\uploads\\ and filled with consistent? data. But I must be missing something...
When I click WD Live I can see a a new blank window in the explorer, and that's all!
By the way, WD Data Export tab has anything to do with this subject? or is it another extra feature just for sending data to WD network?
Any clue? What am I missing?
clientraw.txt is as follows:
Meteohub_Version_2.7 6.8 9.1 135 28.9 54 1009.2 0.00 0.98 387.14 0.0 0.0 - - - 20 - - 0 0.0 - - - - - - - - - 15 26 01 15:26_Cardona_-_Pinallet 0 - 11 08 - - - - - - - 28.9 35.4 29.1 18.9 20 _ 0 4.4 4.8 3.2 2.9 1.5 1.3 1.0 1.7 1.0 1.7 2.0 1.6 1.4 0.9 0.4 1.7 4.9 7.2 8.2 9.9 14.0 18.7 4080 11/08/2008 35.6 25.0 29.1 18.9 - 4.4 4.8 3.2 2.9 1.5 1.3 1.0 1.7 1.0 1.7 28.6 27.4 25.9 24.4 23.1 21.3 20.5 19.5 19.3 19.1 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 30.2 18.9 30.0 11.3 0 _ _ 135.0 _ 0 - - - - - - - - - - - 1014.2 1009.2 14.0 _ _ - - 20.0 18.0 0.0 2008 _ 0 0 0 135 135 135 135 293 293 270 315 293 270 - - 6.8 - 41.921111 1.683056 !!C10.37kf!!
Other files (3) are similar
TIA,
Chill
TIA,
Chill
Chill wrote:In my case I have 2.7 (last version), all 4 files in \\myweb\\uploads\\ and filled with consistent? data. But I must be missing something...
TIA,
Chill
the code from the meteohub manual how to embed WDL into html is no longer valid. It does work with Firefox, but not with IE, you will only see a white window frame
Here´s the new code>
It´s also in your Weather Display Live install folder at<html>
<head>
<meta http-equiv=Content-Type content="text/html; charset=ISO-8859-1">
<meta name="keywords" content="Weather Display Live, Weather Display, Weather Station,Weather Software">
<title>Weather Display Live</title>
<script type="text/javascript" src="swfobject.js"></script>
</head>
<body style="background:#ffffff;">
<!-- URL's used in the movie-->
<!-- http://www.weather-display.com-->
<!-- text used in the movie-->
<!-- Weather Display Live for Weather Display, the Weather Software for Weather Stations-->
<div id="flashcontent" align="center" class="autosize"><b>Weather Display Live</b><br />You need to install v8, or greater, of Flash Player from <a href="http://www.adobe.com">Adobe</a> and have javascript enabled to view Weather Display Live.</div>
<script type="text/javascript">
//Enter your details here!!
var pathToWdlconfig = "http://www.yourwebsite.com/wdlconfig.xml";
var widthOfWdl = "100%";
var heightOfWdl = "100%";
var backgroundColourOfWdl = "#ffffff"
var versionOfWdl = "wdlv6_02.swf";
var so = new SWFObject(versionOfWdl+"?"+pathToWdlconfig, versionOfWdl, widthOfWdl, heightOfWdl, "8", backgroundColourOfWdl);
so.addParam("quality", "high");
so.addParam("wmode", "transparent");
so.write("flashcontent");
</script>
</body>
</html>
\\Weather Display Live\\upload\\index.html
You do not need to set the FQDM in the code, it also works with relative path:
Meaning, if wdlconfig.xml is in the root folder of your website, then this line will do
var pathToWdlconfig = "wdlconfig.xml"
It works fine on my site:
http://wetterstation-honsolgen.de
BTW: Latest version of WDL is 6.02
At least you have data in your files - mine are empty but still uploading on the correct schedule! Interesting! On you WD Live screen - you should assign your sensors and then hit save - it sounds like this saves the template for WD Live.... For your uploads - you have to activate these in Graph Upload section.....
Gregg
Gregg
Your answer has double-point reward.
My question was using WDL within meteohub, and you put lite on this... I checked with a PC with Firefox installed, and that's what I was looking for. It works a treat!
But then you showed me how to embed the applet in my web page. So thanks again.
Trouble is I'm a Windows user (same for most of my web visitors), with just IE on our systems. Then can't I use WD Live feature?
You comment latest version for WLD is 6.02, but when installing meteohub 2.7 it came with 5.4. Must I update this software? Can I do it within Windows?
Are there any other chances not too difficult for a Windows user like me?
TIA,
Chill
WFPost - is that a Joomla site your using! Just wondering how you inserted your live weather to work or if your just using a wrapper.... I can't seem to get mine to work other than the wrapper route - I get serial number problems any other way...
I´m not talking about meteohubs root folder, but the websites root folder.Chill wrote:wfpost, Thanks for your help.wfpost wrote:
Assuming I'm a Windows user, with IE and so far not being able to reach meteohub root, can't I use WD Live feature?
TIA,
Chill
I assume you do upload the four clientraw***.txt files to an external FTP-Server.
The folder on that FTP is your external website.
In the same folder you have to store this files
wdlconfig.xml
wdlv6_02.swf
swfobject.js
I´d recommend using the latest WDL version, because it comes with a graphical applet editor. Great stuff!
You get the lastest WDL version 6.02 from here >>
http://www.weather-display.com/files.php
After installing the downloaded fil, you have entries in your Programs and in your programs folderWeather Display Live Downloads
Weather Display Live v6.02
Read more about Weather Display Live
Version on 6 August 2008 - 22:26:17 6.8 MB Download
C:\\Programs\\weather Display Live\\...
The above three files you need to save with your external FTP server are in the C:\\Programs\\weather Display Live\\upload Folder
wfpost,
This subject goes faster than my hands...
So, if I don't misunderstand you, I need to buy a WDL license, then instal it in my PC, so I can upload the files you comment, and then, by embedding the applet the way you taught me:
Would the users see it under IE WEB browser?
I think I understood the rest of your ideas.
Thanks again...
Chill
Thanks again...
Chill
No simple FTP-site and no Joomla.AAMFlyer wrote:WFPost - is that a Joomla site your using! Just wondering how you inserted your live weather to work or if your just using a wrapper.... I can't seem to get mine to work other than the wrapper route - I get serial number problems any other way...
What do you mean with wrapper route?
Is it because the website that stores my files is
http://www.myway.de/honsolgen
and you can access the site with the URL
which is a FRAME REDIRECT domain, from my email domain that is only 6 Euros a year ;-)
I was wondering myself that to work, but that´s what WDL writes with their FAQ about redirecting.
In other words:
My WDL serial number is registered to
www.myway.de/honsolgen and this site is also running in any other site as long as the orginal frame is called from www.myway.de/honsolgen
Cheers,
Wolfgang
You can test it with the version I gave you, but if you want to get rid of the hugeChill wrote:wfpost,
Thanks again...
Chill
EVALUATION VERSION line in the applet you´ll need to buy a serial no.
You can test it locally, using the meteohub share, because then you can enter any 10-digit serial no into wdlconfig.xml
You call then the applet with
M:\\myweb\\uploadswdlive.html
M:\\ is my meteohub network share \\\\meteohub\\public
enter only any 10-digit number in wdlconfig.xml
<!-- Start of Basic settings -->
<serialno>1234567890</serialno>
Only open the local html file with your wdl code in your browser.
You can copy the new WDL6.02 version to your meteohub share, as I said 5.04 is outdated and does not work with the old code in IE.
Wrapper is just a Joomla thing to incorporate another website... I do something similar to you for the serial number issue - I do a redirect at the server level rather than a Frame Redirect... Thanks!wfpost wrote:No simple FTP-site and no Joomla.AAMFlyer wrote:WFPost - is that a Joomla site your using! Just wondering how you inserted your live weather to work or if your just using a wrapper.... I can't seem to get mine to work other than the wrapper route - I get serial number problems any other way...
In other words:
Cheers,
Wolfgang
