ProxySFTP. **solved**
Roustikost
Post by Roustikost »
has anyone had success to send ProxySFTP updates to the Saratoga template?
Hoster is 1and1 in Germany.
It is clear that the Meteobridge PRO SFTP service doesn't work with them.
I tried to apply all the information found in the Forum and the details of the ProxySFTP function through the Meteobridge server as per Sept. 30, 2023 Release, without any luck.
Any ideas?
Meteobridge PRO
Software 6.0, Nov. 7
Thank you
Re: ProxySFTP
May be it helps when you post your event definition (without the password of course)? Otherwise it is impossible to help ;-)
Roustikost
Re: ProxySFTP
Thanks for the reply. Tried too many options and parameters instead of keeping the definitions simple.
ProxySFTP works fine without issues.
