can't open device /dev/ttyMH **semi-solved**
jleonard99
Post by jleonard99 »
*update: 29/11/2024*
I tried progressively earlier versions of MB, 6.0, 5.9, 5.8, 5.7, 5.6. Regardless if the version, the logs shows the missing /dev/ttyMH device.
My best guess is the USB interface card in the Vantage bit the dust. I can't verify it, but it's the only piece I can't directly test. A quick review of the on-line logs shows the data stopped flowing around mid July. I'll mark this case semi-solved.
Bummer - time to upgrade! I ordered an MB PRO2. My wife will appreciate fewer wires and plugs on the counter!
*original message: 28/11/2024*
Just upgraded my license on my TL-MR3020 V1.x. I'm able to access the MR3020 web interface; it upgraded OK.
My MR3020 is now running Meteobridge 6.0, build 15435, 11/26/2024, FW 1.4.
I'm using a Davis Vantage Pro2 with USB logger connected through a hub to the MR3020.
The Davis Vantage is receiving and displaying weather data from the sensors OK. I see the steady, blinking "X" on it's console.
ISSUE: MR3020 isn't connecting to Vantage. Data isn't being gathered or transmitted. I power cycled all the devices several times and verified wired connections. Hardware has not changed - I've been using this same physical setup since 2018 or.
On the "Weather Station->Primary Station" screen I selected "Vantage", "USB Serial", and note that the "Device" drop-down doesn't offer any options. I also note that there is a red circle with a white dash next to the Vantage name in the drop-down.
Below is a clip of the last entries in the log on the MR3020. Suggestions?
logger (28.11.2024 07:06:21): message above repeats 17 times.
logger (28.11.2024 07:06:21): child process received timeout signal (14).
logger (28.11.2024 07:06:22): data logger stopped.
logger (28.11.2024 07:06:22): parent process to be terminated.
logger (28.11.2024 07:06:22): historical data loaded (25 records).
logger (28.11.2024 07:06:22): data logger started.
logger (28.11.2024 07:06:23): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (28.11.2024 07:06:23): station 0 (Vantage), connect to station failed.
logger (28.11.2024 07:06:27): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (28.11.2024 07:06:27): services paused.
logger (28.11.2024 07:06:53): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (28.11.2024 07:08:23): message above repeats 3 times.
logger (28.11.2024 07:08:24): give up waiting for sensors after 120 secs.
logger (28.11.2024 07:08:24): services activated.
logger (28.11.2024 07:08:53): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (28.11.2024 07:09:23): message above repeats 1 time.
Re: can't open device /dev/ttyMH **semi-solved**
Typical symptoms when the mandatory passive USB hub is not used.
