Meteobridge Pro stopped working. **solved**
Uti
Post by Uti »
today all in a sudden my Meteobridge Pro stopped working!
when connecting to the IP Address I get the following Error.
The CGI process did not produce any response
connecting to http://10.10.30.101/cgi-bin/luci/ is working but I dont know how to fix the issue.
Can someone Help Please.
Thanks Urs
EddyG
Re: Meteobridge Pro stopped working
Post by EddyG »
I'm having the same problem, also yesterday. I did a restart of my Meteobridge Pro to install version 6.1 and after reboot the system stopped working.
The only thing it shows in the display is the IP address.
I was able to get a log file and it looks like it cannot find the meteobridge.cfg file.
Need some help too.
Eddy
screamingdead
Post by screamingdead »
Same with my Pro, rebooted after a power cut and can only get "the cgi process did not produce any response".
miraculon
Post by miraculon »
Same here. I am having trouble getting into it with SSH.
I understand that the fix is to revert the version, but I can't get to it to perform this.
I got to the luci screen. I'll see what I can do there.
I figured out the SSH issue with a command line switch. I can't tell how to revert the version here, so I guess that I will have to wait for a fix from Boris.
I don't know what worked, I rebooted from Luci and the normal tabbed screen came up. Just to be sure, I selected "Stick to V 6.0". Maybe the fix was applied and I just happened to pick it up during the last reboot?
Greg H.
rwvdk
Post by rwvdk »
UPDATE: ... After a factory reset and loading my backup everything is OK now ...
FYI ...
Same problem here with Meteobridge RED Pro+ !!!
Only WRT root login possible ...
I have no idea how I can fix my Meteobridge...
screamingdead
Another power cut from storm Darragh, pro has rebooted again and is now working.
EddyG
Post by EddyG »
Here It's also up and running again after I loaded an old .cfg file with "luci".
Very weird, looks like there's something wrong with the new update, so I selected to stick with 6.0 either.
Took me a couple of hours but glad It's working again.
Eddy
rwvdk
Post by rwvdk »
Problem was with the archive format of the application stack. Is fixed by now.
doncurtis
Re: Meteobridge Pro stopped working. **solved**
Post by doncurtis »
OK, you fixed the bad download, now, how do we users get our meteobridge devices working again? I tried rebooting my metrobridge up and running again?
Dlink DR505L
Don
Don
andresegea
Post by andresegea »
It wouldn’t be possible upload the version 6 for download it and install throught luci in flash section?
doncurtis wrote: Mon Dec 09, 2024 4:29 pm OK, you fixed the bad download, now, how do we users get our meteobridge devices working again? I tried rebooting my metrobridge up and running again?
Dlink DR505L
Don
A reboot should fix it. Does your DIR505L have problems?
andresegea wrote: Mon Dec 09, 2024 6:31 pm It wouldn’t be possible upload the version 6 for download it and install throught luci in flash section?
No, application stack is far to big to be stored in flash, it needs to run from Ramdisk.
And I do not recommend to experiment with luci, as this will easily have bad side effects.
doncurtis
Post by doncurtis »
admin wrote: Tue Dec 10, 2024 2:31 am
Dlink DR505L
Don
Yes, stupidly, I did the "5 flash reset" to restart. I have a configure file from an earlier download. How can I load it?
Don
Don
doncurtis wrote: Tue Dec 10, 2024 7:58 pm
Dlink DR505L
Don
Don
"System - Admin" tab gives you the option to upload a previously stored settings file
