Meteobridge doesn't work. **solved**
andresegea
Post by andresegea »
This morning my Dir-505 stopped working, I can't access the Meteobridge interface, everything seems to be working fine, but it doesn't go past the loading page. The strange thing is that I have another Dir-505 on standby, and when I connect it I get the same error. I have reset it and loaded the Meteobridge firmware 1.3, but it doesn't go past the loading page.
Could you help me?
Re: Meteobridge doesn't work
I will try to check with my DIR505.
Can you login via SSH?
andresegea
I can't connect via ssh "no matching key exchange method found. Your offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1"
Neither of the 2 dir-505 loads the meteobridge tabs, I have reset them and reinstalled the meteobridge-dir-505-v1.3.bin
I found this in the router log, it's weird
Meteobridge disconnected from router at. Connection time: 7d 4m. Data used: 115.27 MB (uploaded) /8.49 GB (downloaded).
Dec 9, 2024 11:09
The download image was in an incompatible tar format. Just released version has that fixed, please reboot your DIR 505 and you should be fine again.
andresegea
admin wrote: Tue Dec 10, 2024 1:59 pm The download image was in an incompatible tar format. Just released version has that fixed, please reboot your DIR 505 and you should be fine again.
I have rebooted the Dir-505 and it still doesn't work. The strange thing is that I had another Dir-505 as a backup and it gave me the same problem.
I have bought a raspberry, so when I get it working, I will contact you to transfer the license. Is that possible?
andresegea wrote: Tue Dec 10, 2024 8:01 pm
I tested on my DIR 202 and it works here.
Yes we can migrate the license if you have update support for it. If not, you need to purchase an update license first.
