- IMG_20241216_045608.jpg (124.67 KiB) Viewed 3088 times
I've assumed that my VP2 transmits on European frequency but I don't know how to prove it other than to check the label attached to it which I'll do in the morning. Data from the VP2 is received by the Vue console.
I'm sure the MBPRO2 is working correctly, I removed the battery from the old Vue ISS last week as data from it was received by the MBPRO2.
I've set the MBPRO2 to narrow bandwidth and run through various sensitivity settings at 3 minute intervals. Lastly I set all the transmitters to ISS.
Log posted below.
_-----------_---------_-------
logger (16.12.2024 03:47:52): message above repeats 1 time.
system (16.12.2024 03:50:40): stop of logging process initiated.
logger (16.12.2024 03:50:40): parent process received termination signal (15).
logger (16.12.2024 03:50:40): child process received termination signal (15).
logger (16.12.2024 03:50:40): disconnect station 0 (Meteostick Vantage): exit
logger (16.12.2024 03:50:40): disconnect station 9 (System Data): exit
system (16.12.2024 03:50:44): start of logging process initiated.
logger (16.12.2024 03:50:44): databases connected. Update interval 3600 seconds.
logger (16.12.2024 03:50:44): data logger started.
logger (16.12.2024 03:50:46): connect station 0 (Meteostick Vantage via serial).
logger (16.12.2024 03:50:46): connect station 9 (System Data via Plug-in).
logger (16.12.2024 03:50:49): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.12.2024 03:50:49): services paused.
logger (16.12.2024 03:50:55): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (16.12.2024 03:50:55): station 0 (Meteostick Vantage), MBPRO2RF Version 1.0
logger (16.12.2024 03:50:55): station 0 (Meteostick Vantage), debug off
logger (16.12.2024 03:50:55): station 0 (Meteostick Vantage), verbose off
logger (16.12.2024 03:50:55): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (16.12.2024 03:50:55): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (16.12.2024 03:50:55): station 0 (Meteostick Vantage), filter on
logger (16.12.2024 03:50:55): station 0 (Meteostick Vantage), rx threshold set to -85db
logger (16.12.2024 03:50:55): station 0 (Meteostick Vantage), listening to tx 1
logger (16.12.2024 03:50:55): station 0 (Meteostick Vantage), bandwidth narrow
logger (16.12.2024 03:50:55): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
logger (16.12.2024 03:52:46): give up waiting for sensors after 120 secs.
logger (16.12.2024 03:52:46): services activated.
system (16.12.2024 03:53:20): stop of logging process initiated.
logger (16.12.2024 03:53:20): parent process received termination signal (15).
logger (16.12.2024 03:53:20): child process received termination signal (15).
logger (16.12.2024 03:53:20): disconnect station 0 (Meteostick Vantage): exit
logger (16.12.2024 03:53:20): disconnect station 9 (System Data): exit
system (16.12.2024 03:53:23): start of logging process initiated.
logger (16.12.2024 03:53:23): databases connected. Update interval 3600 seconds.
logger (16.12.2024 03:53:23): data logger started.
logger (16.12.2024 03:53:25): connect station 0 (Meteostick Vantage via serial).
logger (16.12.2024 03:53:25): connect station 9 (System Data via Plug-in).
logger (16.12.2024 03:53:28): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.12.2024 03:53:28): services paused.
logger (16.12.2024 03:53:34): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (16.12.2024 03:53:34): station 0 (Meteostick Vantage), MBPRO2RF Version 1.0
logger (16.12.2024 03:53:34): station 0 (Meteostick Vantage), debug off
logger (16.12.2024 03:53:34): station 0 (Meteostick Vantage), verbose off
logger (16.12.2024 03:53:34): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (16.12.2024 03:53:34): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (16.12.2024 03:53:34): station 0 (Meteostick Vantage), filter on
logger (16.12.2024 03:53:34): station 0 (Meteostick Vantage), rx threshold set to -75db
logger (16.12.2024 03:53:34): station 0 (Meteostick Vantage), listening to tx 1
logger (16.12.2024 03:53:34): station 0 (Meteostick Vantage), bandwidth narrow
logger (16.12.2024 03:53:34): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
logger (16.12.2024 03:55:25): give up waiting for sensors after 120 secs.
logger (16.12.2024 03:55:25): services activated.
system (16.12.2024 03:56:25): stop of logging process initiated.
logger (16.12.2024 03:56:25): parent process received termination signal (15).
logger (16.12.2024 03:56:25): child process received termination signal (15).
logger (16.12.2024 03:56:25): disconnect station 0 (Meteostick Vantage): exit
logger (16.12.2024 03:56:25): disconnect station 9 (System Data): exit
system (16.12.2024 03:56:28): start of logging process initiated.
logger (16.12.2024 03:56:29): databases connected. Update interval 3600 seconds.
logger (16.12.2024 03:56:29): data logger started.
logger (16.12.2024 03:56:30): connect station 0 (Meteostick Vantage via serial).
logger (16.12.2024 03:56:30): connect station 9 (System Data via Plug-in).
logger (16.12.2024 03:56:33): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.12.2024 03:56:33): services paused.
logger (16.12.2024 03:56:39): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (16.12.2024 03:56:39): station 0 (Meteostick Vantage), MBPRO2RF Version 1.0
logger (16.12.2024 03:56:39): station 0 (Meteostick Vantage), debug off
logger (16.12.2024 03:56:39): station 0 (Meteostick Vantage), verbose off
logger (16.12.2024 03:56:39): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (16.12.2024 03:56:39): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (16.12.2024 03:56:39): station 0 (Meteostick Vantage), filter on
logger (16.12.2024 03:56:39): station 0 (Meteostick Vantage), rx threshold set to -65db
logger (16.12.2024 03:56:39): station 0 (Meteostick Vantage), listening to tx 1
logger (16.12.2024 03:56:39): station 0 (Meteostick Vantage), bandwidth narrow
logger (16.12.2024 03:56:39): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
nbiot (16.12.2024 03:57:16): module reset failed
logger (16.12.2024 03:58:30): give up waiting for sensors after 120 secs.
logger (16.12.2024 03:58:30): services activated.
system (16.12.2024 03:59:40): stop of logging process initiated.
logger (16.12.2024 03:59:40): parent process received termination signal (15).
logger (16.12.2024 03:59:40): child process received termination signal (15).
logger (16.12.2024 03:59:40): disconnect station 0 (Meteostick Vantage): exit
logger (16.12.2024 03:59:40): disconnect station 9 (System Data): exit
system (16.12.2024 03:59:43): start of logging process initiated.
logger (16.12.2024 03:59:43): databases connected. Update interval 3600 seconds.
logger (16.12.2024 03:59:43): data logger started.
logger (16.12.2024 03:59:45): connect station 0 (Meteostick Vantage via serial).
logger (16.12.2024 03:59:45): connect station 9 (System Data via Plug-in).
logger (16.12.2024 03:59:48): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.12.2024 03:59:48): services paused.
logger (16.12.2024 03:59:54): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (16.12.2024 03:59:54): station 0 (Meteostick Vantage), MBPRO2RF Version 1.0
logger (16.12.2024 03:59:54): station 0 (Meteostick Vantage), debug off
logger (16.12.2024 03:59:54): station 0 (Meteostick Vantage), verbose off
logger (16.12.2024 03:59:54): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (16.12.2024 03:59:54): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (16.12.2024 03:59:54): station 0 (Meteostick Vantage), filter on
logger (16.12.2024 03:59:54): station 0 (Meteostick Vantage), rx threshold set to -55db
logger (16.12.2024 03:59:54): station 0 (Meteostick Vantage), listening to tx 1
logger (16.12.2024 03:59:54): station 0 (Meteostick Vantage), bandwidth narrow
logger (16.12.2024 03:59:54): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
logger (16.12.2024 04:01:45): give up waiting for sensors after 120 secs.
logger (16.12.2024 04:01:45): services activated.
system (16.12.2024 04:03:33): stop of logging process initiated.
logger (16.12.2024 04:03:33): parent process received termination signal (15).
logger (16.12.2024 04:03:33): child process received termination signal (15).
logger (16.12.2024 04:03:33): disconnect station 0 (Meteostick Vantage): exit
logger (16.12.2024 04:03:33): disconnect station 9 (System Data): exit
system (16.12.2024 04:03:36): start of logging process initiated.
logger (16.12.2024 04:03:37): databases connected. Update interval 3600 seconds.
logger (16.12.2024 04:03:37): data logger started.
logger (16.12.2024 04:03:38): connect station 0 (Meteostick Vantage via serial).
logger (16.12.2024 04:03:38): connect station 9 (System Data via Plug-in).
logger (16.12.2024 04:03:41): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.12.2024 04:03:41): services paused.
logger (16.12.2024 04:03:47): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (16.12.2024 04:03:47): station 0 (Meteostick Vantage), MBPRO2RF Version 1.0
logger (16.12.2024 04:03:47): station 0 (Meteostick Vantage), debug off
logger (16.12.2024 04:03:47): station 0 (Meteostick Vantage), verbose off
logger (16.12.2024 04:03:47): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (16.12.2024 04:03:47): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (16.12.2024 04:03:47): station 0 (Meteostick Vantage), filter on
logger (16.12.2024 04:03:47): station 0 (Meteostick Vantage), rx threshold set to -45db
logger (16.12.2024 04:03:47): station 0 (Meteostick Vantage), listening to tx 1
logger (16.12.2024 04:03:47): station 0 (Meteostick Vantage), bandwidth narrow
logger (16.12.2024 04:03:47): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
logger (16.12.2024 04:05:38): give up waiting for sensors after 120 secs.
logger (16.12.2024 04:05:38): services activated.
system (16.12.2024 04:06:27): stop of logging process initiated.
logger (16.12.2024 04:06:27): parent process received termination signal (15).
logger (16.12.2024 04:06:27): child process received termination signal (15).
logger (16.12.2024 04:06:27): disconnect station 0 (Meteostick Vantage): exit
logger (16.12.2024 04:06:27): disconnect station 9 (System Data): exit
system (16.12.2024 04:06:30): start of logging process initiated.
logger (16.12.2024 04:06:30): databases connected. Update interval 3600 seconds.
logger (16.12.2024 04:06:30): data logger started.
logger (16.12.2024 04:06:32): connect station 0 (Meteostick Vantage via serial).
logger (16.12.2024 04:06:32): connect station 9 (System Data via Plug-in).
logger (16.12.2024 04:06:35): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.12.2024 04:06:35): services paused.
logger (16.12.2024 04:06:41): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (16.12.2024 04:06:41): station 0 (Meteostick Vantage), MBPRO2RF Version 1.0
logger (16.12.2024 04:06:41): station 0 (Meteostick Vantage), debug off
logger (16.12.2024 04:06:41): station 0 (Meteostick Vantage), verbose off
logger (16.12.2024 04:06:41): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (16.12.2024 04:06:41): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (16.12.2024 04:06:41): station 0 (Meteostick Vantage), filter on
logger (16.12.2024 04:06:41): station 0 (Meteostick Vantage), rx threshold set to -35db
logger (16.12.2024 04:06:41): station 0 (Meteostick Vantage), listening to tx 1
logger (16.12.2024 04:06:41): station 0 (Meteostick Vantage), bandwidth narrow
logger (16.12.2024 04:06:41): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
logger (16.12.2024 04:08:32): give up waiting for sensors after 120 secs.
logger (16.12.2024 04:08:32): services activated.
system (16.12.2024 04:09:44): stop of logging process initiated.
logger (16.12.2024 04:09:44): parent process received termination signal (15).
logger (16.12.2024 04:09:44): child process received termination signal (15).
logger (16.12.2024 04:09:44): disconnect station 0 (Meteostick Vantage): exit
logger (16.12.2024 04:09:45): disconnect station 9 (System Data): exit
system (16.12.2024 04:09:48): start of logging process initiated.
logger (16.12.2024 04:09:48): databases connected. Update interval 3600 seconds.
logger (16.12.2024 04:09:48): data logger started.
logger (16.12.2024 04:09:50): connect station 0 (Meteostick Vantage via serial).
logger (16.12.2024 04:09:50): connect station 9 (System Data via Plug-in).
logger (16.12.2024 04:09:53): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.12.2024 04:09:53): services paused.
logger (16.12.2024 04:09:59): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (16.12.2024 04:09:59): station 0 (Meteostick Vantage), MBPRO2RF Version 1.0
logger (16.12.2024 04:09:59): station 0 (Meteostick Vantage), debug off
logger (16.12.2024 04:09:59): station 0 (Meteostick Vantage), verbose off
logger (16.12.2024 04:09:59): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (16.12.2024 04:09:59): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (16.12.2024 04:09:59): station 0 (Meteostick Vantage), filter on
logger (16.12.2024 04:09:59): station 0 (Meteostick Vantage), rx threshold set to -30db
logger (16.12.2024 04:09:59): station 0 (Meteostick Vantage), listening to tx 1
logger (16.12.2024 04:09:59): station 0 (Meteostick Vantage), bandwidth narrow
logger (16.12.2024 04:09:59): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
logger (16.12.2024 04:11:50): give up waiting for sensors after 120 secs.
logger (16.12.2024 04:11:50): services activated.
system (16.12.2024 04:13:22): stop of logging process initiated.
logger (16.12.2024 04:13:22): parent process received termination signal (15).
logger (16.12.2024 04:13:22): child process received termination signal (15).
logger (16.12.2024 04:13:22): disconnect station 0 (Meteostick Vantage): exit
logger (16.12.2024 04:13:22): disconnect station 9 (System Data): exit
system (16.12.2024 04:13:25): start of logging process initiated.
logger (16.12.2024 04:13:25): databases connected. Update interval 3600 seconds.
logger (16.12.2024 04:13:25): data logger started.
logger (16.12.2024 04:13:27): connect station 0 (Meteostick Vantage via serial).
logger (16.12.2024 04:13:27): connect station 9 (System Data via Plug-in).
logger (16.12.2024 04:13:30): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.12.2024 04:13:30): services paused.
logger (16.12.2024 04:13:36): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (16.12.2024 04:13:36): station 0 (Meteostick Vantage), MBPRO2RF Version 1.0
logger (16.12.2024 04:13:36): station 0 (Meteostick Vantage), debug off
logger (16.12.2024 04:13:36): station 0 (Meteostick Vantage), verbose off
logger (16.12.2024 04:13:36): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (16.12.2024 04:13:36): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (16.12.2024 04:13:36): station 0 (Meteostick Vantage), filter on
logger (16.12.2024 04:13:36): station 0 (Meteostick Vantage), rx threshold set to -85db
logger (16.12.2024 04:13:36): station 0 (Meteostick Vantage), listening to tx 1
logger (16.12.2024 04:13:36): station 0 (Meteostick Vantage), bandwidth narrow
logger (16.12.2024 04:13:36): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
system (16.12.2024 04:15:13): stop of logging process initiated.
logger (16.12.2024 04:15:13): parent process received termination signal (15).
logger (16.12.2024 04:15:13): child process received termination signal (15).
logger (16.12.2024 04:15:13): disconnect station 0 (Meteostick Vantage): exit
logger (16.12.2024 04:15:13): disconnect station 9 (System Data): exit
system (16.12.2024 04:15:16): start of logging process initiated.
logger (16.12.2024 04:15:16): databases connected. Update interval 3600 seconds.
logger (16.12.2024 04:15:16): data logger started.
logger (16.12.2024 04:15:18): connect station 0 (Meteostick Vantage via serial).
logger (16.12.2024 04:15:18): connect station 9 (System Data via Plug-in).
logger (16.12.2024 04:15:21): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.12.2024 04:15:21): services paused.
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), transmitter 2 registered as ISS
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), transmitter 3 registered as ISS
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), transmitter 4 registered as ISS
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), transmitter 5 registered as ISS
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), transmitter 6 registered as ISS
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), transmitter 7 registered as ISS
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), transmitter 8 registered as ISS
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), MBPRO2RF Version 1.0
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), debug off
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), verbose off
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), filter on
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), rx threshold set to -85db
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), listening to tx 1 2 3 4 5 6 7 8
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), bandwidth narrow
logger (16.12.2024 04:15:27): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
logger (16.12.2024 04:17:18): give up waiting for sensors after 120 secs.
logger (16.12.2024 04:17:18): services activated.
