Meteobridge Export
Seedubs
Meteobridge Export
Post by Seedubs »
Firstly, how much data does meteobridge store? I am upgrading my Vantage Vue to a Pro2 and want to export my existing data, I thought I could still do that via Wunderground, but apparently not. So is there a way to export whatever Meteobridge has stored?
Seedubs
Re: Meteobridge Export
Post by Seedubs »
For info, I have just followed someone's guide (very good guide, many thanks) to set up a sqldb and it is exporting every 10 mins, but what I really wanted was my historic data from the past few years, if not that, then at least my min/max's that are visible in the 'Live Data' tab of meteobridge.
Meteobridge does not store data when using the router platforms from TP-Link et al.
When you have a PRO, NANO SD or RPI with SD card Meteobridge stores data locally. Here you can make use of the export options on "Database" tab to define time frames and formats you want to have the export file to look like. Wiki has examples, there are also export template examples, so you should be able to define your preferred export format. To feed this into your preferred database will then be a second step on your IT.
