new Pro2 from ambient weather yesterday, Feb 4. I added all Davis sensors to it, was working properly. Added Airlink to Pro2, and then SD card not supported.
Storage: SD card not supported, no local storing of data
test5m (05.02.2025 19:55:10): database daemon stalled, will be restarted now.
dbase (05.02.2025 19:55:10): process started.
dbase (05.02.2025 19:55:10): Can't open database: unable to open database file
dbase (05.02.2025 19:55:10): process stopped.
new Pro2, SD card not supported **solved**
Re: new Pro2, SD card not supported ** Solved **
I rolled back to 5.9 and reboot
SD card worked, did another reboot to get latest version, SD card worked again.
Found the fix from a different post --> viewtopic.php?t=17869
I will post here if problems arise again
