Problems with station2 stops all the other datalogger
meteosantasusanna
Post by meteosantasusanna »
i have 3 stations conected to my meteobridge rpi. The station 2 will frooze anytime. when it's does then also the station0 and 1 not works to send data. Thats the log:
logger (16.02.2025 09:24:41): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:24:49): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:25:03): message above repeats 4 times.
logger (16.02.2025 09:25:11): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:25:13): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:25:37): message above repeats 8 times.
logger (16.02.2025 09:25:41): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:25:45): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:26:00): message above repeats 4 times.
logger (16.02.2025 09:26:11): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:26:15): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:26:39): message above repeats 9 times.
logger (16.02.2025 09:26:41): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:26:49): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:27:03): message above repeats 4 times.
logger (16.02.2025 09:27:11): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:27:13): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:27:37): message above repeats 11 times.
logger (16.02.2025 09:27:41): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:27:51): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:28:09): message above repeats 4 times.
logger (16.02.2025 09:28:11): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:28:13): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:28:39): message above repeats 8 times.
logger (16.02.2025 09:28:41): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:28:49): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:29:03): message above repeats 4 times.
logger (16.02.2025 09:29:11): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:29:13): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:29:37): message above repeats 8 times.
logger (16.02.2025 09:29:41): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:29:45): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:30:01): message above repeats 4 times.
logger (16.02.2025 09:30:11): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:30:13): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:30:39): message above repeats 9 times.
logger (16.02.2025 09:30:41): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:30:49): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:31:00): message above repeats 3 times.
logger (16.02.2025 09:31:11): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:31:13): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:31:37): message above repeats 9 times.
logger (16.02.2025 09:31:41): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:31:51): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:32:09): message above repeats 5 times.
logger (16.02.2025 09:32:11): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:32:13): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:32:39): message above repeats 9 times.
logger (16.02.2025 09:32:41): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:32:49): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:33:02): message above repeats 4 times.
logger (16.02.2025 09:33:11): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:33:13): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:33:37): message above repeats 8 times.
logger (16.02.2025 09:33:41): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:33:45): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:34:00): message above repeats 4 times.
logger (16.02.2025 09:34:11): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:34:13): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:34:39): message above repeats 9 times.
logger (16.02.2025 09:34:41): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:34:49): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:35:00): message above repeats 3 times.
logger (16.02.2025 09:35:11): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:35:13): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:35:37): message above repeats 9 times.
logger (16.02.2025 09:35:41): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:35:51): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:36:09): message above repeats 4 times.
logger (16.02.2025 09:36:11): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:36:13): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:36:39): message above repeats 8 times.
logger (16.02.2025 09:36:41): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:36:49): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:37:03): message above repeats 5 times.
logger (16.02.2025 09:37:11): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:37:13): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:37:37): message above repeats 10 times.
logger (16.02.2025 09:37:41): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:37:45): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:38:00): message above repeats 4 times.
logger (16.02.2025 09:38:11): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:38:13): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:38:39): message above repeats 9 times.
logger (16.02.2025 09:38:41): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
logger (16.02.2025 09:38:49): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (16.02.2025 09:39:01): message above repeats 3 times.
logger (16.02.2025 09:39:11): station 2 (GW1000), error make socket 192.168.178.119: port 45000: unknown (22)
Is there anyway to not stop all the other meteobrife functions for 1 station? ist there any way to send a sms o mail when this problems ocurrs?
Re: Problems with station2 stops all the other datalogger
One of the processes that handles data from the weather station has been canceled for some reason. You can disable that the logger gets restarted, when a certain station does not work properly and does not send any data.
What caused the process to die is hard to say without having access to your system and you also post close to no information about your setup.
