Meteobridge NANO SD doesn´t send data
oporo
Post by oporo »
Hi.
I use Meteobridge NANO SD to send meteo data. But from 4 days ago, MB doesnt run ok. I save and reboot and meteobridge send data.
But it doesnt send more. And in SYSTEM/LOGGING I read "Access point operation disabled 1082 secs after boot."
What´s the problem?
Re: Meteobridge NANO SD doesn´t send data
After a reboot that is correct in regard the AP of the Nano. On the Network this can be observed following a reboot.
On the Network tab is the WiFi Client configured correctly? Is the IP Address configured correctly?
Assuming the Nano has worked ok prior to 4 days ago, has anything in your network/WiFi/router changed?
