NANO SD: How to migrate to a larger SD card (the pro way)
General information and solutions to the most prominent issues
These are the steps to migrate from a microSD card to larger one. Please notice that you do this on your own and that the NANO will go out of warranty when changing cards. Getting the microSD card out of the socket can easily damage the NANO when done with force or without patience.
  • Power down NANO SD, extract old SD card.
  • Connect old an new card to your PC. Both cards need to be connected to do a successful cloning.
  • You cannot use normal file copy commands for disk content cloning, it needs to be a low level copy of raw disk data.
    • PC/Mac: Use Balena Etcher to do a low level cloning of your old card (source) to the new one (target).
    • Linux: You can use "dd if=/dev/sdx of=/dev/sdy bs=1M" where "sdx" is the old card and "sdy" is the target card. "sdx" and "sdy" need to address the complete device, not a partition on the device like "sdx1".
  • Remove old and new card from the PC. Leave old card untouched as a backup in case the cloning or further migration steps don't go well.
  • Insert new card into NANO SD and power up NANO SD. When NANO SD starts operating everything will look as before. If not, you are in trouble, abort here and go back to old card. Card cloning has failed.
  • Although the physical size of the card is larger now, neither the partition, nor the filesystem in that partition does know of it. Following steps enlarge partition (1st step) and then enlarge filesystem (2nd step). It will need you to give commands on a Linux shell, just to let you feel like a pro ;-)
  • Login via SSH, user is "root", password is the same password you defined for HTTP access with your browser.
  • When prompted give command "/home/meteohub/maxdisk". Operation will take a wile. When it concludes with "done" you are fine.
  • Logging in with your browser should show larger SD card on "System - Info" tab. If errors occur, please report here: viewforum.php?f=61
Output of "/home/meteohub/maxdisk" should look like this:
Current usable size of SD card is 1.8G
  Shutting down services logger, wnet, database, samba ... done
  Unmount SD card ... done
  Do file system check (and repair if needed) ... done
  SD card size is 15 GB (31116288 sectors a 512 byte)
  DOS Partion table patched at pos 458-461
  Syncing disks ... done
  Resizing file system ... done
  Remount SD card ... done
  Restarting services database, logger, wnet, samba ... done
New usable size of SD card is 14.6G
Re: NANO SD: How to migrate to a larger SD card (the pro way)
In case you want to adapt the "maxdisk" script to other Platforms, here is the source code:
#!/bin/sh
if [ ! -e "/dev/mmcblk0p1" ]
then
  echo "Error: SD card not on the list of accepted cards for NANO"
  exit 1
fi
if [ $(dd if=/dev/mmcblk0 skip=510 bs=1 count=2 2>/dev/null | hexdump -e '"%02x"') != "aa55" ]
then
  echo "Error: SD card does not have the expected DOS partition table"
  exit 1
fi
if [ $(dd if=/dev/mmcblk0 skip=454 bs=1 count=4 2>/dev/null | hexdump -e '"%08x"') != "000000fd" ]
then
  echo "Error: Partition table on SD card does not provide the expected partition start address"
  exit 1
fi
echo "Current usable size of SD card is `df -h | grep '/dev/mmcblk0p1' | awk '{print $2}'`"
echo -n "  Shutting down services "
touch /var/run/notest 2>/dev/null
/etc/init.d/loggerd stop >/dev/null 2>/dev/null
echo -n "logger, "
/etc/init.d/wnetd stop >/dev/null 2>/dev/null
echo -n "wnet, "
/etc/init.d/databased stop >/dev/null 2>/dev/null
echo -n "database, "
/etc/init.d/samba stop >/dev/null 2>/dev/null
echo "samba ... done"
echo -n "  Unmount SD card ... "
umount /tmp/mnt 2>/dev/null
echo "done"
echo -n "  Do file system check (and repair if needed) ... "
e2fsck -fy /dev/mmcblk0p1 2>/dev/null >/dev/null
echo "done"
MSIZE=`cat /sys/class/mmc_host/mmc0/mmc0\:aaaa/block/mmcblk0/size`
echo "  SD card size is $((MSIZE / 2000000)) GB ($MSIZE sectors a 512 byte)"
MLEN=$((MSIZE - 253))
v1="`printf '%x' $(((MLEN >> 0) % 256))`"
v2="`printf '%x' $(((MLEN >> 8) % 256))`"
v3="`printf '%x' $(((MLEN >> 16) % 256))`"
v4="`printf '%x' $(((MLEN >> 24) % 256))`"
echo -ne "\x$v1\x$v2\x$v3\x$v4" | dd conv=notrunc of=/dev/mmcblk0 bs=1 seek=458 >/dev/null 2>/dev/null
echo "  DOS Partion table patched at pos 458-461"
echo -ne "  Syncing disks ... "
echo -ne "p\nw\n" | fdisk /dev/mmcblk0 2>/dev/null >/dev/null
echo "done"
echo -n "  Resizing file system ... "
resize2fs /dev/mmcblk0p1 2>/dev/null >/dev/null
echo "done"
echo -n "  Remount SD card ... "
mount /dev/mmcblk0p1 /tmp/mnt 2>/dev/null
if [ $? -ne 0 ]
then
  echo "ERROR!!!"
  exit 1
else
  echo "done"
fi
echo -n "  Restarting services "
/etc/init.d/databased start >/dev/null 2>/dev/null
/etc/init.d/loggerd start >/dev/null 2>/dev/null
echo -n "logger, "
/etc/init.d/wnetd sart >/dev/null 2>/dev/null
echo -n "wnet, "
/etc/init.d/samba start >/dev/null 2>/dev/null
rm /var/run/notest 2>/dev/null
echo "New usable size of SD card is `df -h | grep '/dev/mmcblk0p1' | awk '{print $2}'`"
