Help Meteobridge Pro 2. **solved**
alex1989
Post by alex1989 »
Good afternoon
I recently purchased a Davis pro 2 with Meteobridge pro 2. I connected the Meteobridge in LAN with my Wi-Fi router. Then the IP appeared and everything was ok. I connected to the
browser with the IP on my PC and tried to configure the entire station. After that the browser page disappears with a message "page expired". On the Meteobridge instead I find the warning "no network found".
I disconnected the meteobridge from the router and from the power supply and reconnected. The yellow LED starts to flash quickly for 5 minutes but in the end the same warning "network not found" appears.
Maybe the Console would have been better :(
What could have happened? Maybe I changed settings during the configuration that could have led to all this?
Sorry for my English
Thanks so much for help
Re: Help Meteobridge Pro 2
Have you tried connecting via ethernet/cable?
alex1989
Post by alex1989 »
Yes I solved it :D
Thanks :wink:
