Incidental wrong recording of total rain
robr57
Post by robr57 »
Since some weeks (I think since 6.2 but not sure) I noticed that sometimes my rain0total has 25,4 mm rain recorded. Even when there is no rain at all.
This happened now approximately 6 times in last month. I also run Davis Vantage Pro/2 console in parallel, but this does not get these wrong readings.
Luckily I can change the Database to remove the spurious wrong amount, but I dont know how to prevent this.
System
Platform: Meteobridge PRO *
RAM: 61500 kB total, 10548 kB free (82% used)
Storage ATP: Internal 865 MB total, 355 MB free (59% used, 331.7 yrs)
SW Version: Meteobridge 6.2 (Jun 7 2025, build 15572), FW 1.4
Uptime: 0 hours, 30 minutes Buffer: 2 items (0%)
Power Data: 5.59V 446mA 2.50W
Devices
USB Front: Kingston DataTraveler 2.0 30008 MB (partitioned)
USB Back:
The signals seem to be ok:
# Sensor Signal Metric Data Imperial Data
0 Indoor 5s 19.3% 36.8°C 30% 1012.4hPa (1012.0hPa) 98.2°F 30% 29.90inHg (29.88inHg)
0 Soil #11 21s -64db 14.9°C 0cbar 58.8°F 0cbar
0 Soil #13 1m -66db 0.0°C 0cbar 32.0°F 0cbar
0 Soil #10 39s -66db 15.9°C 42cbar 60.6°F 42cbar
0 Outdoor 8s -65db 17.3°C 84% (dew14.6°C,hi17.3°C,wb15.4°C) 63.1°F 84% (dew58.3°F,hi63.1°F,wb59.7°F)
0 Wind #1 1s -65db 0.0m/s (avg 0.0m/s) 0° N 0.0mph (avg 0.0mph) 0° N
0 Wind 53s -62db 2.4m/s (avg 2.4m/s) 183° S 5.4mph (avg 5.4mph) 183° S
0 Rain 16s -65db rate 0.0mm/h rate 0.00in/h
0 Solar 11s -64db 366W/m² 366W/m²
0 Soil #12 34s -65db 0.0°C 0cbar 32.0°F 0cbar
Any clue what is causing this ?
Regards, Rob
Re: Incidental wrong recording of total rain
May be it is some RF false reading. What is selected RF threshold on "Station" tab? According to the strong signals coming in I would recommend "-75 db" to block RF noise effectively.
robr57
Post by robr57 »
Thanks for tip. It was on -90 dB. Now set to -80 dB. There is one station with -74 dB. Will see how it behaves.
