MBPro software version stuck on v5.5. **solved**
snowmet
Post by snowmet »
My Meteobridge Pro is showing the following software version:
Meteobridge 5.5 (Mar 4 2023, build 14907), FW 1.4
I have set the version control to Use installed version
I clicked on the RF Module Update Firmware button and the update reported success:
"Stopping loggerd... wait done.
Downloading flash tools and recent Meteostick firmware... done.
Extracting archive... done.
Resetting USB device... done.
Flashing Meteostick firmware... done.
Starting loggerd... done.
Stick successfully updated!"
I then clicked on Save and Apply and, when that completed, I clicked on Reboot.
However, Information still shows the software version still as 5.5 and is the latest version in the version control list
Have I missed doing something?
Save and apply firmware update log and log after reboot:
Log after Save and Apply for firmware update
logger (04.07.2025 15:28:36): data logger (version 5.4, build 14907) started.
logger (04.07.2025 15:28:38): connect station 0 (Meteostick Vantage via USB serial).
logger (04.07.2025 15:28:38): connect station 9 (System Data via Plug-in).
logger (04.07.2025 15:28:38): error while doing write on socket 5551 (2): No such file or directory
logger (04.07.2025 15:28:40): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (04.07.2025 15:28:40): station 0 (Meteostick Vantage), Meteostick Version 3.4
logger (04.07.2025 15:28:40): station 0 (Meteostick Vantage), debug off
logger (04.07.2025 15:28:40): station 0 (Meteostick Vantage), verbose off
logger (04.07.2025 15:28:40): station 0 (Meteostick Vantage), output raw
logger (04.07.2025 15:28:40): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (04.07.2025 15:28:40): station 0 (Meteostick Vantage), filter on
logger (04.07.2025 15:28:40): station 0 (Meteostick Vantage), rx threshold set to -90db
logger (04.07.2025 15:28:40): station 0 (Meteostick Vantage), listening to tx 1
logger (04.07.2025 15:28:40): station 0 (Meteostick Vantage), bandwidth narrow
logger (04.07.2025 15:28:40): station 0 (Meteostick Vantage), chip auth ok: 14
logger (04.07.2025 15:28:40): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
logger (04.07.2025 15:28:41): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (04.07.2025 15:28:41): services paused.
database (04.07.2025 15:29:20): database sync done (44 tables, 186/1848 writes).
logger (04.07.2025 15:30:37): give up waiting for sensors after 120 secs.
logger (04.07.2025 15:30:37): services activated.
database (04.07.2025 15:41:39): process terminated normally.
database (04.07.2025 15:41:40): process started.
system (04.07.2025 15:41:40): stop of logging process initiated.
system (04.07.2025 15:41:48): start of logging process initiated.
logger (04.07.2025 15:41:49): databases connected. Update interval 3600 seconds.
logger (04.07.2025 15:41:49): data logger (version 5.4, build 14907) started.
logger (04.07.2025 15:41:52): connect station 0 (Meteostick Vantage via USB serial).
logger (04.07.2025 15:41:52): connect station 9 (System Data via Plug-in).
logger (04.07.2025 15:41:52): error while doing write on socket 5551 (2): No such file or directory
logger (04.07.2025 15:41:52): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (04.07.2025 15:41:52): station 0 (Meteostick Vantage), Meteostick Version 3.4
logger (04.07.2025 15:41:52): station 0 (Meteostick Vantage), debug off
logger (04.07.2025 15:41:52): station 0 (Meteostick Vantage), verbose off
logger (04.07.2025 15:41:52): station 0 (Meteostick Vantage), output raw
logger (04.07.2025 15:41:52): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (04.07.2025 15:41:52): station 0 (Meteostick Vantage), filter on
logger (04.07.2025 15:41:52): station 0 (Meteostick Vantage), rx threshold set to -90db
logger (04.07.2025 15:41:52): station 0 (Meteostick Vantage), listening to tx 1
logger (04.07.2025 15:41:52): station 0 (Meteostick Vantage), bandwidth narrow
logger (04.07.2025 15:41:52): station 0 (Meteostick Vantage), chip auth ok: 14
logger (04.07.2025 15:41:52): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
logger (04.07.2025 15:41:55): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (04.07.2025 15:41:55): services paused.
Log after Reboot:
oled (04.07.2025 14:42:36): process started.
setup (04.07.2025 15:47:07): use UTC stamp 2025-07-04 14:47:07 (1 tries)
database (04.07.2025 15:47:17): process started.
database (04.07.2025 15:47:18): Content of RAM database restored.
wnetd (04.07.2025 15:47:19): process started.
system (04.07.2025 15:47:20): start of logging process initiated.
wnetd (04.07.2025 15:47:20): send data thread started (pid:2494 tid:2495)
logger (04.07.2025 15:47:20): databases connected. Update interval 3600 seconds.
logger (04.07.2025 15:47:20): data logger (version 5.4, build 14907) started.
logger (04.07.2025 15:47:21): connect station 0 (Meteostick Vantage via USB serial).
logger (04.07.2025 15:47:21): connect station 9 (System Data via Plug-in).
logger (04.07.2025 15:47:23): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (04.07.2025 15:47:23): station 0 (Meteostick Vantage), Meteostick Version 3.4
logger (04.07.2025 15:47:23): station 0 (Meteostick Vantage), debug off
logger (04.07.2025 15:47:23): station 0 (Meteostick Vantage), verbose off
logger (04.07.2025 15:47:23): station 0 (Meteostick Vantage), output raw
logger (04.07.2025 15:47:23): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (04.07.2025 15:47:23): station 0 (Meteostick Vantage), filter on
logger (04.07.2025 15:47:23): station 0 (Meteostick Vantage), rx threshold set to -90db
logger (04.07.2025 15:47:23): station 0 (Meteostick Vantage), listening to tx 1
logger (04.07.2025 15:47:23): station 0 (Meteostick Vantage), bandwidth narrow
logger (04.07.2025 15:47:24): station 0 (Meteostick Vantage), chip auth ok: 14
logger (04.07.2025 15:47:24): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
logger (04.07.2025 15:47:25): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (04.07.2025 15:47:25): services paused.
database (04.07.2025 15:47:51): database sync done (44 tables, 85/1848 writes).
logger (04.07.2025 15:49:21): give up waiting for sensors after 120 secs.
logger (04.07.2025 15:49:21): services activated.
Re: MBPro software version stuck on v5.5
RF firmware updates and MB firmware are two different entities. Version control option is for the MB version not the RF.
To update MB firmware set Version Control: [get newest on boot] then [Reboot], button bottom of tab between the [Save and Apply] and [Power Off]
When MB reboots latest firmware should be installed and you then have the option to set [use installed version] or [stick to version xx] etc which will control inadvertent FW updates if the MB restarts for any reason.
snowmet
Post by snowmet »
Thanks, now sorted.
My mistake was not realising get latest on boot was available on the tab (all the way at the bottom!)
Your log tells that RF module is on most recent version 3.4
snowmet
Post by snowmet »
