Davis console shows measurements, Nano not
JWR
Post by JWR »
I have an issue, maybe can someone help me?
I have installed a nano SD in a VP2 console. The measurements of the stations are visible at the console, but the Meteobridge Nano SD don't show the measurements at the Live Data or at the Min/Max.
I have the ISS at port 6 and Temp/Hum at port 4.
Can that be a problem?
Or could it happen that de batteries are low in the stations?
Does someone know the answer?
Thank you in advance!
Re: Davis console shows measurements, Nano not
Can your reach the GUI of the NANO?
What does it say on "System - Logging" tab?
JWR
Post by JWR »
It does say:
station 0 (Vantage), execution of setup script failed (console is not responding).
(I just changed the ISS to OFF OFF OFF OFF)
So you have an ISS and a separate Temp Hum station then? ISS on TX 6, Temp/Hum Tx ID 4 and these display data on the Console ok?
What does the Nano tab Station>Davis Station Setup with Configure sensors and mapping to transmitters ID's look like?
Does this Nano have a Black or Red strap and what power adapter is being used to power the console?
JWR
Post by JWR »
I just think that it is an problem with the power. So we will check that first and maybe I come back.
