The website of an old user of Leuven Template needs to be replaced.
But before doing that the MB Pro Red should work again. It is probably 8 yours old.
The company who sold it is not active anymore.
No data is displayed, log shows multiple errors
As i have no experience with a Pro Red i doubt what advice I should give.
User has two consoles which display the data.
Both consoles also has an IP-logger. Could try to switch from Red to an ip-logger.
But maybe there is another cause such as failed USB stick or the low battery causing this.
I already noticed that some items appear on WU after noon.
Attached a screenshot from the MB-Pro RED
Thanks in advance,
Metepbridge Pro Red errors, What could be the cause
- Schermafbeelding 2025-09-07 om 16.42.29.png (833.54 KiB) Viewed 1499 times
Re: Metepbridge Pro Red errors, What could be the cause
The internal USB memory "stick" is not available
Further testing revealed that both the front and back USB are not working either.
Also the "RED" part of the PRO failed.
Using the IP connection to the consoles work, but as there is no USB permanent memory, no data can be stored.
Maybe the " USB chip/connection" is not working anymore?
The company who sold the device is out of business, and the device is over 5 years old.
Is there any chance the device can be repaired?
Regards,
Regards,
Yes, I repair (including OLED replacement) and send back (within EU) for 50 Euros.
Please ship (naked Meteobridge, no cables, no power supply) to
smartbedded GmbH
Querweg 35
24632 Lentföhrden
Germany
Payment will be requested via Paypal, when the repair is successfully done.
Regards,
Boris
smartbedded GmbH
Querweg 35
24632 Lentföhrden
Germany
Regards,
Boris
