TP-Link TL-WR902AC version. 4 (EU), flashing firmware
Posted: Wed Dec 17, 2025 11:24 am
I`m not able to successfully flash my new TP-Link TL-WR902AC v4 with meteobridge-tl-wr902v3-v1.3.bin.
Using the guide for v3.x, renaming file as explained, with a comment for it should work for v4 as well, as I understand.
Flashing seem to be OK every time I tried. But after flashing the router starting up, led flashes on power first for 3 sec, then power-led goes off, and then all led flashes 1 sec, and this repeat endlessly.
Tried flashing several times from windows with 64tftp software, and also with Transfer on mac. Same results. No errors, but ends up as explained above.
Read the workaround-tip in another thread, about first flash with OpenWRT and then flash the firmware from inside OpenWRT.
Successfully flashed with OpenWRT, logged in and should load the new meteobridge firmware, meteobridge-tl-wr902v3-v1.3.bin.
But when doing the file-checks before the actual flashing, I stopped.
See attachment to thread.
Is it safe to continoue this upgrade... ?
Any other tip to get this unit flashed with Meteobridge.. ?
