Cannot Download Data From Meteobridge Pro. **solved**
Robbie936
Post by Robbie936 »
For the last 2 days i cannot download the archive from my meterobridge pro using either cumulus (roginal), cumuluisMX or weatherlink.
It will only partially download....say 6% and then say it is completed.
I have rebooted the meteobridge and it is running the latest version.
Re: Cannot Download Data From Meteobridge Pro
Which archive are you referring? More details please. Where does Weatherlink come into it? Is this a Meteobridge Pro or a NanoSD?
Robbie936
Post by Robbie936 »
Thank you for your reply.
Trying to download the daily archive for my vantage pro2 using cumulus MX or cumulus or weatherlink was not working. Any of them wouyld only partially download the data (i do it daily).
I have powered down the logger and powered it up again, it may have fixed the problem.
Thew setup is the vantage pro2 wireless to a vantage pro 2 console with logger attached. This is connected to the meteobridge.
Cumulus Version 1, cumulus MX and Weatherlink V6.05 all get data from the meteobridge but only one can run at any one time.
None of them could download the data.
Ok my take on this setup is WeatherLink V6.05 would be downloading through the Console logger as WL and MB don't talk to each other (as such), but the MB talks through the logger to get data but with MB in the system then yes there needs to be a window of opportunity for WL to talk to and and download from the logger and typically MB wants priority hence the time out?
To clarify further what type of logger are you using? I am also assuming the MB is connected via Ethernet?
Robbie936
Post by Robbie936 »
I am using the 6510 usb connected logger and only ever connect either cumulus, cumulusMX or weatherlink 6.05 at a time.
However i think the reboot of the logger may have fixed the problem.
I'll see how it goes.
Thank you
Robbie936
Post by Robbie936 »
Powerwing down the logger did the trick.
It now downloads for all three programs and is quick, much quicker than it has been.
Thank you for ytoure assistance.
