Page 1 of 2
Aurora 2026 Version Beta !
Posted: Tue Jan 06, 2026 6:46 pm
by weatherist34
Good day or good evening ..
See New Aurora 2026 thread ...
viewtopic.php?t=18943
Re: Aurora 2026 Version Beta !
Posted: Wed Jan 07, 2026 11:59 am
Brian, this looks very promising. Reducing the may themes to one with more flexibility is a great idea.
Posted: Sun Jan 11, 2026 4:27 pm
by weatherist34
x
Posted: Mon Jan 12, 2026 5:19 pm
by weatherist34
x
Posted: Wed Jan 14, 2026 2:40 pm
by davidmc36
I recently got my original Aurora messed up and cannot see charts anymore. Since it is broken anyway, is it possible to try this Beta?
TIA
D
Posted: Wed Jan 14, 2026 5:16 pm
by ToTo
weatherist34 wrote: Mon Jan 12, 2026 5:19 pm
now compiling bottom modules please suggest ideas/sensors if you have any ?
I would like to see an option in the settings to remove these grey boxes below the text for all modules. I have done this on my German site for all modules used, and I don't think it has any negative impact on readability.
Posted: Thu Jan 15, 2026 7:16 am
by weatherist34
davidmc36 wrote: Wed Jan 14, 2026 2:40 pm
TIA
D
Good morning no problem ... provide a url ? and a contact email I could probably fix your messed up version .
The Beta great your interested its about a week or so away still a little bit of fine tuning in display but will let you know when its in a stable state to test and can implement ideas if you have any ?..thats what im interested in to get ideas now has opposed to later has I dont plan on doing this week in week out beyond end of march , april,may summer season kicks in so I get preoccupied outdoors
Posted: Thu Jan 15, 2026 7:17 am
by weatherist34
ToTo wrote: Wed Jan 14, 2026 5:16 pm
Good morning sure I see what I can come up with but no guarantees but will take a look at an option setting.
Posted: Sun Jan 25, 2026 8:06 pm
by weatherist34
x
Posted: Sun Jan 25, 2026 8:07 pm
by weatherist34
x
Posted: Thu Jan 29, 2026 11:42 am
by weatherist34
x
Posted: Sat Feb 07, 2026 5:11 pm
by davidmc36
weatherist34 wrote: Thu Jan 15, 2026 7:16 am
TIA
D
Hi. Thanks for your reply. And many thanks for being a developer of things that are well beyond my level of "Coding" It appears you have moved to a higher version in a new thread. I will drop in there also.
I wonder, if you might be so gracious, and had a few minutes.....if I give you my credentials, could you log into my Control Panel and see if there is an obvious fix? I can see a chart each day, but month and yearly are blank. The data appears to be on the server, but not visible on my webpage.
https://www.morewoodweather.ca/Aurora/index.php
If you are available, please contact d_c_o_l_p_i_t_t_s_at_b_e_l_l_dot_net (remove underscores of course lol)
Posted: Sun Feb 08, 2026 7:52 am
by weatherist34
good morning
you need to run the weather34-chart-end-of-day.php file ive just run it through browser now you have data
https://www.morewoodweather.ca/Aurora/c ... -month.php
see the pdf setup in the download master Weather34_Aurora_MKII_Meteobridge_Setup_Guide.pdf
screenshot of pdf section for end of day...brian
- eod.png (116.53 KiB) Viewed 1279 times
Posted: Mon Feb 09, 2026 2:30 am
by davidmc36
I have all of that set up and have since I started using the W34 on my site. What happened was, I was doing something else, and inadvertantly caused the W34 to stop working. I tried to overlay the newer Master Template (could not find original version from several years ago) and the site "works" now but I cannot see any charts on the interface except current day. All the data seems to be there from back to 2020.....but.......
Those errors popped up on the Admin interface during that mess-up.
Posted: Mon Feb 23, 2026 7:03 pm
by davidmc36
So my chart problem was simply missing data. The csv files were blank. I thought I had replaced them but obviously not.
I still see the API errors though.
