Aurora 2026 Version Beta !
Good day or good evening ..
See New Aurora 2026 thread ...
viewtopic.php?t=18943
Re: Aurora 2026 Version Beta !
Brian, this looks very promising. Reducing the may themes to one with more flexibility is a great idea.
x
x
davidmc36
Post by davidmc36 »
I recently got my original Aurora messed up and cannot see charts anymore. Since it is broken anyway, is it possible to try this Beta?
TIA
D
weatherist34 wrote: Mon Jan 12, 2026 5:19 pm now compiling bottom modules please suggest ideas/sensors if you have any ?
I would like to see an option in the settings to remove these grey boxes below the text for all modules. I have done this on my German site for all modules used, and I don't think it has any negative impact on readability.
davidmc36 wrote: Wed Jan 14, 2026 2:40 pm I recently got my original Aurora messed up and cannot see charts anymore. Since it is broken anyway, is it possible to try this Beta?
TIA
D
Good morning no problem ... provide a url ? and a contact email I could probably fix your messed up version .
The Beta great your interested its about a week or so away still a little bit of fine tuning in display but will let you know when its in a stable state to test and can implement ideas if you have any ?..thats what im interested in to get ideas now has opposed to later has I dont plan on doing this week in week out beyond end of march , april,may summer season kicks in so I get preoccupied outdoors :-)
ToTo wrote: Wed Jan 14, 2026 5:16 pm
Good morning sure I see what I can come up with but no guarantees but will take a look at an option setting.
x
x
x
davidmc36
Post by davidmc36 »
weatherist34 wrote: Thu Jan 15, 2026 7:16 am
TIA
D
Hi. Thanks for your reply. And many thanks for being a developer of things that are well beyond my level of "Coding" It appears you have moved to a higher version in a new thread. I will drop in there also.
I wonder, if you might be so gracious, and had a few minutes.....if I give you my credentials, could you log into my Control Panel and see if there is an obvious fix? I can see a chart each day, but month and yearly are blank. The data appears to be on the server, but not visible on my webpage.
https://www.morewoodweather.ca/Aurora/index.php
If you are available, please contact d_c_o_l_p_i_t_t_s_at_b_e_l_l_dot_net (remove underscores of course lol)
good morning
you need to run the weather34-chart-end-of-day.php file ive just run it through browser now you have data
https://www.morewoodweather.ca/Aurora/c ... -month.php
see the pdf setup in the download master Weather34_Aurora_MKII_Meteobridge_Setup_Guide.pdf
screenshot of pdf section for end of day...brian
davidmc36
Post by davidmc36 »
I have all of that set up and have since I started using the W34 on my site. What happened was, I was doing something else, and inadvertantly caused the W34 to stop working. I tried to overlay the newer Master Template (could not find original version from several years ago) and the site "works" now but I cannot see any charts on the interface except current day. All the data seems to be there from back to 2020.....but....... :?: :?: :?:
Those errors popped up on the Admin interface during that mess-up.
davidmc36
Post by davidmc36 »
So my chart problem was simply missing data. The csv files were blank. I thought I had replaced them but obviously not. :oops:
I still see the API errors though.
