Use Imperial Checkbox Missing. **solved**
AL7CR
Post by AL7CR »
I can not find the "Use Imperial" setting for the database edit tabs. There are screen shots on the website showing it on the same line as the "Edit Hour Data" label but it is not present on my screen. It is also not present on the system localization tab.
Does this feature still exist in the latest version? I am using a NanoSD installed and updated today if it matters.
Thanks for the help.
Re: Use Imperial Checkbox Missing
The Nano/SD has a [Use imperial units] box in the Station>Primary Station.Station Settings
AL7CR
Post by AL7CR »
So it does! Thanks, that is what I needed.
