Send data for two stations to weather networks
pfeimich
Post by pfeimich »
I have two Davis weather stations. One is sending data directly to a Meteobridge (meteoplug) Nano SD and one is sending data to the new Meteobridge Pro 2 with nbiot.
So I have included the nbiot data as a second weather station in the Meteobridge Nano SD to use the data. This is working pretty fine.
But now I have the problem to send this data to weather networks. As far as I understand it is only possible to send data to weather networks only for "one" station. Yes I can switch between the two stations in the physical and logical sensor section but this is not very helpful.
So how can I send the data from my second nbiot Meteobridge to the weather networks?
It would be create if there is an easy possibility. Otherwise the Nbiot Meteobridge is pretty useless for me if I cannot sent its data to weather networks.
Or am I missing something?
Thanks in advance.
Best regards
Michael
Re: Send data for two stations to weather networks
Meteobridge cannot feed multiple instances of the same weather network. I don't know of any software that can. You could run a virtual Meteobridge on a VM and have this feeding the NBIOT data to weather networks of your liking. This way you avoid staking up Meteobridge HW.
