"Storing settings failed" message in MB Services-Events result window
patrickk64
Post by patrickk64 »
Meteobridge 6.3 (May 3 2026, build 4183), FW 1.4
RPi 3 Model B
This is the full message:
"Error: Storing settings failed (/root/meteobridge.conf): backup of /root/meteobridge.conf failed: Read-only file system
Meteobridge settings successfully reloaded"
Is there anything I can do to mitigate this? I'm trying to make some revisions to some events.
Thank you very much.
Re: "Storing settings failed" message in MB Services-Events result window
Your root file system is in read-only mode. It is a HW issue with your RPI setup.
Most common reason is, that the used cheap non-SLC SD card is worn out.
