WB Pro2: Unable To Remote Login. **solved**
Car54
Post by Car54 »
I enabled a WB Pro2 for remote login:
When trying to access the remote login URL, an error message appears:
I have successfully used remote login for a different WB Pro2, as well as a Nano SD.
If need be, I can allow access to the WB Pro2 via DDNS.
VP2+ Nano SD & Pro2
Car54
Re: WB Pro2: Unable To Remote Login
Post by Car54 »
I rebooted the WB Pro2. The Remote Login URL changed and it now works.
VP2+ Nano SD & Pro2
Glad to hear that it works again. That the remote login URL has changed concerns me a bit.
Could you please send remote login URL and password to "info(at)meteobridge.com"?
I ask as changing link indicates a changing MAC, which can generate issues later on. Therefore,
I would like to have a look, if you are impacted by spontaneous MAC changes. If so, I could fix it remotely.
