After updating to the latest Meteobridge version, the Weather Underground forecast stops working after a few hours.
This happens on both:
• Meteobridge Aurora (cloud)
• Meteobridge W34 (local server)
Behavior:
• A new API key works initially
• After some hours, forecast disappears/stops updating
• API test then returns:
"code":"CDN-0001",
"message":"Invalid apiKey."
I tested 3 different API keys with the same result.
The problem started only after the latest Meteobridge update. Before that, forecasts worked normally and stable.
Could this be a WU authentication/session bug or compatibility issue with the latest Meteobridge version?
Thank you.
Platform: Raspberry Pi 4 Model B Rev 1.1 Rev 1.1
RAM: 3895 MB total, 3729 MB free (4% used)
Storage: ATP SLC, 1.5 GB total, 722 MB free (53% used, 254.2 yrs)
SW Version: Meteobridge 6.3 (May 11 2026, build 4191), FW 1.3
Uptime: 1 days, 20 hours, 31 minutes Buffer: 1 items (0%)
WU Forecast Stops Working After Latest Meteobridge Update
