TP-Link Meteobridge won't load application stack. **solved**
ANZAC
Post by ANZAC »
It went down after a power outage on July 5 and hasn't come back since.
It is on my network and getting an IP address. When I connect to it I get the usual landing/loading page and no web UI:
"Meteobridge Landing Page (FW 1.4)
You got here, because Meteobridge application stack you wanted to access could not be loaded from the Internet. Most common reason for that is a bad network configuration of the Meteobridge device, that keeps the unit in endless fast blinking LED mode. From here you can do one of the following:
The network must be fine because it is connected to the network and all of the network information on that screen looks 100% correct.
Usually, a press of the reset button would solve this, but it doesn't seem to be coming back this time.
Any ideas?
Re: TP-Link Meteobridge won't load application stack.
Pressing the reset button does not do what you might expect. It can reset it to factory defaults, etc. Please read the wiki.meteobridge.com in regard to reset button operation!
Is it a MR3020? Is it connected via Ethernet cable?
ANZAC
Post by ANZAC »
No, WiFi.
Yes, TL-MR3020.
I was connecting to it fine over wifi (to see the FW1.4 boot screen) - therefore wifi was working.
I gave up and plugged it into the LAN directly, working now. I have a copy of my config in case there's an issue.
