Realtime txt
Posted: Fri Jul 17, 2026 8:19 pm
by spd2612
I have uploaded a realtime text file to my meteobridge pro 2 and cant get it to populate any data from my Davais weather station
It is reading my station as I have it sending data another way how can I get that data to populate the template/realtime.txt ?
my realtime text has a different name I did not want to overwrite the orig
Re: Realtime txt
Posted: Fri Jul 17, 2026 11:19 pm
by Mattk
Did you change anything in the your realtime.txt file or simply make a copy and rename? Not populating maybe then in Events Definition? Or is the upload not working? How is the event setup?
Re: Realtime txt
Posted: Fri Jul 17, 2026 11:23 pm
by spd2612
This is for a WS40 weather plugin that runs out of wordpress There support is not very good on this
This is what is said but Medobridge pro 2 does not have this config
How to install on Meteobridge
Download the file using the button above, or directly: ws40_meteobridge_master_v5_0.txt
In your Meteobridge admin panel, go to Services → Weather Network.
Add a new "Custom Script" target, select "Push" and upload the v5 template.
Set the push URL to your WS40 station realtime endpoint and set interval to 5 minutes.
In WS40 → Settings → Mapping, run the test — WS40 auto-detects the Master KV format and shows all 68 keys.
looking at my realtime.txt file and ws40_meteobridge_master_v5_0.txt neither one of them have any data in them
Re: Realtime txt
Posted: Sat Jul 18, 2026 1:05 am
by Mattk
Sorry that doesn't make much sense to me, is this an Event or a Weather Network?
Weather Network (Weather Nets) is a separate tab, under Services Tab there is only Events & Service Settings, both Tabs serve different purposes.
Uploading a script/Template etc can be one under System/Administration [Upload Files] but appear to be referring to Scripts as templates which have different folders, which one does this need to be uploaded to? Not sure there is a "Push" option?
The setting of a URL and interval to 5 minutes to me is referring to adding a Weather Network which are pre-configured. It's all rather vague?
However the realtime.txt file/setup should be straight forward as an event?
Re: Realtime txt
Posted: Sat Jul 18, 2026 1:14 am
by spd2612
There is no data in my realtime.txt file in MB and I dont see anywhere I can set it up
- realtime_mb.jpg (107.59 KiB) Viewed 373 times
wordpress gets pointed to the files on MB
- event.jpg (44.75 KiB) Viewed 373 times
Re: Realtime txt
Posted: Sat Jul 18, 2026 2:19 am
by Mattk
Ok, realtime.txt is a simple template not a Weather Network
Under Services/Events create a new Event Definition, Select Service to match intended template type (such as FTP etc) noting not all services support all template options, select Event Type and Add Service Event. Fill out the required parameters which will depend on the Event Type, Select File for Upload (template:realtime will be an option) and [Save]
If you copied/renamed the default realtime.txt then the file needs to be in the Template folder.
Re: Realtime txt
Posted: Sat Jul 18, 2026 7:39 am
by spd2612
It will not put a new realtime.txt file in does not appear meteobridge will write to the template folder
I got the realtime txt file to upload to meteotemplate/templates but i cant get any of the data to populate it
Re: Realtime txt
Posted: Sat Jul 18, 2026 9:05 am
by Mattk
What does your Event definition look like? Where are you wanting to upload the output to/
