I stumbled over something while uploading files with the "template:filename" mechanism and thought I'd mention it, in case it's
useful to you. No urgency — I found a way around it.
Setup: Meteobridge 6.4 on a Raspberry Pi 4 Model B Rev 1.1 (originally build 4267, now on 4297 via auto-update). A nightly
script on the device writes some JSON text files, and scheduled events
upload them via SFTP as templates.
What I see: Smaller files (up to ~200 KB) arrive on the server just fine. But one file grew over time to about 290 KB, and that one arrives
incomplete: the end is missing, and near the point where it gets cut off there is a strange bit of text in the middle of the data that reads
. This happens every night in the same way; as soon as I keep the file smaller, everything is fine again.cond_template_buf <
So it seems there is a maximum size for template files somewhere around 270 KB? I couldn't find anything about it in the wiki — maybe I just
missed it.
My workaround: I now split the export into two smaller files and upload them with two events — works perfectly, so I'm all set. And I
could imagine the limit is simply there so that the smaller platforms can keep up, which would make perfect sense.
Just wanted to let you know, since the cut-off file looks a bit confusing at first. Happy to send you a sample file if that helps.
Update Aug 23: One more observation that may be related. My box updated itself to 6.4 build 4287 (Aug 21 2026), and last night the data
logger crashed repeatedly — but only during the two minutes when my two larger template uploads (~150 KB and ~185 KB) were being processed. The
uploads themselves arrived complete and valid, and outside those windows everything runs fine. The log shows for each crash:
child process received termination signal (11) in functions:
termination_handler < get_wssensor_temp10 < get_wssensor < get_set <
get_set_long < get_set < get_set_long < ... (repeats)
and once a variant ending in
. After each crash the logger restarts by itself (with the usual... send_wnet_nosensor < test_inetupload
message) and recovers; the nightly backup afterwards completed normally. On build 4267 the same events ran for days withoutbind (port 22222)
any crash, so this might be new in 4287.
Second night (Aug 24): it reproduces exactly, and got worse — by now the box had auto-updated itself again to build 4297 (Aug 23 2026),
and on that build I got 15 crashes in three bursts, each starting precisely at one of the three upload slots (00:30, 00:45, 01:00;
template sizes ~160/150/185 KB). So builds 4287 and 4297 both show it, while 4267 ran the same events for days without any crash. More
trace variants appeared, all pointing into template/sensor processing:
andskipn < print_wind_sensor* < get_set < get_set_long < ...
.setup_pipe < get_sensorid < print_num_sensor < sensor_copy < get_wssensor < ...
The uploads still arrive complete and valid every
time, but each crash/restart cycle now costs about a minute of per-minute logging (the affected day recorded ~1390 instead of ~1420
minute rows). Happy to provide full log excerpts or remote access if
that helps.
Thanks for the support
BR,
Marco
